I have 12g or 14g silicone wire for the heavy load, itll be around 100mm long.
spec if there are no errors, you've told me the mosfet's, would you have the part numbers for the other components?
All Circuit Resistances are ADDITIVE, including the Mosfets internal resistance.
So your Total Resistance will be Higher than that .08 resistor.
for Longer Tests, Heating will increase resistances, giving different readings.
That is why I asked about the casePossibly you can use the Enclosure as a Heatsink.
However it may need Electrical Insulation.
Can you show the basis of this?Additionally if the Gate Voltage goes below -3.3 Volts, the Internal Resistance of the Mosfets will RISE considerably.
Might be a good idea to use a Separate Battery for the Turn on Voltage.
I think it's time to get my parts on order. I'm confident I can put the circuit together quite neatly.
I will bump this thread with a picture once it's done, I think it deserves it
Id like to give everyone a massive thank you for help.
And spec.. holy $#!t, you practically built it for me! Kudos my friend.
