Does anyone have any good ideas how one could build a voltage divider that can actually deliver decent current (2-3A). The traditional resistor network would not work for obvious reasons.
I want to use this on my drone, the autopilot can take between a 3 and 6 cell battery but I want to power it using a 8 cell. The reason why a normal regulator will not work is that the autopilot must see the battery voltage to allow low battery warnings and fail safe procedures. Using a regulator the autopilot will think the battery is fine all the time and give wrong battery level indications. So the idea is that if I use 8 cells and divide it in half I can tell the autopilot that its running a 4 cell. It would then be happy and correctly monitor the battery voltage.
One idea that came to mind was to use a switching regulator, normally these devices has a small resistor divider circuit connected to the output which provides a reference for setting the output voltage. This might be a long shot but maybe with some modifications I could rather connect this divider circuit to the input and have the reference follow in the input voltage. Hopefully this would create some kind of regulated divider circuit.
Alternatively I could build a custom/discrete SMPS for this purpose but I hoped there might be some easier options?
