davidbrink48
I have a Optex photoelectric detector that can handle 28vdc .2A max output. I need it to control a sprinkler system solenoid which is 24vac. I also need the solenoid to stay on for 5 to 8 seconds regardless of the detector state. In reading the specs on the Optex AX-130, once tripped I believe it stays in an alarm status for 1-2 seconds only. I need to be able to use the detectors 2 second output voltage (28vdc) to control a relay that will hold a 24vac voltage to the solenoid for 5 to 8 seconds. Any suggestions?
Thank you in advance
Dave
Dave
