ok so does anyone know where you can buy such an ignition coil? 300v primary 30kv secondary 100 gain? I cant find it anywhere.
I have not read this entire thread but what i have read it would look that this has lost the plot of how the average ignition system works.
Most small motors have a winding in the flywheel / stator to produce the voltage needed for the ignition system and another winding for the battery system, these are independent of each other.
Some systems have a inductive pickup on the outside of the flywheel for the spark timing and as already mentioned there will be 2 targets for a twin cylinder 180 degrees apart.
A lot of the CDI units charge the capacitors via the ignition windings and are triggered to fire the coil by the inductive pickups, it is all a very simple system.
The OP said 1 plug stopped working , then followed shortly by the second plug.....Have you actually tried replacing the plugs as they can go short circuit, which sounds like the cause of 1 plug to fail before the other.
If you need to remove the potted glue to get things apart than heating the glue/resin with a heat gun (Hot air) will make it go soft and crumbly when hot and can be carefully dug out, in most CDI systems it is the SCR that fails and if replaced normally the unit will work.
A close friend of mine has a business in repairing motorbike ignition systems and it is a common practice to replace the SCR's, rather than removing all the resin/glue to access the scr he often just solders a new one to the bottom of the board as scr's normally fail open circuit the old ones can be left in place.
After testing the board is resealed with resin.
The biggest fault is the use of 400 volt rated SCR's and upgrading them to 600 volt SCR's often cures the problem.
Pete.
It is hard to recommend a source without knowing where you are. HobbyKing has many ignitions, including one for a twin. Ebay has several ignition coils for the Zenoah 2-cycle engines. I personally have used those coils with homebuilt ignitions. Most hobby ignitions operate with a 300V primary and >20KV secondary.
RPM may be a factor to consider. Hobby engines peak out at to 10,000 to 12,000 rpm. If you are running faster, particularly with a twin , you may need to look at coils/systems for motorcycles.
Here are some links to the above:
For a twin: **broken link removed**
John
Seems like no one gives specs. SNAFU. I was looking around and found things such as this: CDI Electronics Chrysler Coil 182-5475 @ MarineEngine.com
Best suggestion is to call CDI Electronics and get a p/n. If you get one post it here too.
Mallory PROMASTER Marine Coil for breaker point or OE electronic ignition - JCWhitney
here are some specs for various mallory coils: **broken link removed**
Are you going to make a PC board for this gizmo?
Personally i think you have received a lot of bad information here ....
I would be hard pressed to think there is not a coil on the machine already for the spark and dont see why it is recommended for you to go shopping for a new one, coils seldom fail, it is normally the CDI or other controlling system (black box as often called) that fails.
Pete.
Maybe you should read why he can't use the coil before criticizing the information he gets here.
Well i looked and cant see the post that indicates why the coil cannot be used.
Perhaps you can point it out, or tell me the exact reason why the coil cant be used.
It obviously use to use a coil of some discription.
Pete.
The current coil is very well placed inside a box filled with glue to keep it away from moist, I cannot get it out in pieces, I tried with my old one, but I will try since this model is abit different.
Personally i think you have received a lot of bad information here and if you start buying coils from here, and CDI units from there, and other crap, you will waste your money and end up with a pile of useless junk.
Step back and work through the problem, step by step, and not assume what the fault is.
The flywheel and stator you linked above shows two coils in the stator, 1 is for the ignition system the other is for battery charging, at a guess i would say the top one that is wrapped up, is the ignition and the bare copper one (at the bottom) is the battery charging system.
The photo dont show the outer of the flywheel, and there might be two targets on the outer for the pickups, or it could be done with how the magnets are spaced within the flywheel.
You can test the voltage out of the stator to the ignition, to do this you require a diode and a capacitor of around 400 volt rating, 1uF should be ok.
The diode is placed in series with 1 stator lead and connected to the capacitor, the other lead is connected to the other side of the capacitor.
A multimeter is used to read the voltage across the capacitor.
Crank the motor over and you should see a voltage on the meter of around a few hundred volts, this proves the stator is generating power and not likely to be the fault.
You can not test this without a capacitor as the AC voltage spike will be too narrow and the meter will not record it, the capacitor stores the charge long enough to be read by the meter. (DC reading)
Be carefull as the voltage will be high and can bite you bad if you touch it, not enough current to kill you, but by hell it will wake you up.
Pete.
If you go over there, introduce yourself in the 650 section explain what you trying to accomplish and ask for a better understanding of how the ignition system works...they will probably give you the best/longest lasting method to do what you want.
Pete.
To OP...2 stroke engines are a fun hobby of mine, especially those on 650 x2's and older Polaris watercraft. check out the forums over at GreenHulk Personal Watercraft Performance Forums for all your watercraft needs. Many of them have posted over at the pwctoday forums once and even the SBT one's before they got all updity. There is some talk on the net and on the above forums about using 750 stators on the 650's. If you go over there, introduce yourself in the 650 section explain what you trying to accomplish and ask for a better understanding of how the ignition system works...they will probably give you the best/longest lasting method to do what you want.
Here is a link that uses MSD parts to do alot of what you want:
http://www.google.com/url?sa=t&sour...sg=AFQjCNGva0q_iLTmoBTEIlllkaSdxqO7sA&cad=rja
If I was going to play with my ski as much as you are, and I have thought about it...I want to convert either the x2 or the polaris slt750 over to electronic fuel injection...now that would be a fun audrino project![]()
If you start a thread, please provide a link. I would like to follow along.
