Azalin
Hello,
My name is Suat. This is my first post on the board.
I have a set of 2HP permanent magnet DC motor, a PWM controller and a console. These are removed from a working treadmill. Everything works when I connect the console to the controller as you see in the photo. I press the "START" button on the console. The relay on the controller clicks, console beeps 3 times and then motor revs.
Only 4 pins to get it working. GND, VCC, REV and SEND.
I want to throw away the console and use the controller and motor in my lathe with variable speed. Just need to wire a potentiometer to the controller but I have no tiny idea how to do it. So my question would be how can I get the controller working with a potentiometer or anything else you can suggest.
Thanks in advance.
Best,
Suat
Thanks in advance.
Best,
Suat
