How Can I Use My Current City Name Tool with GPS Modules in a DIY Location-Based Circuit?
GwyRhys
I'm exploring ways to create a custom electronics project that takes advantage of GPS technology, particularly using a tool like My current city name which leverages the GPS location of a device to identify the current city. The goal is to integrate this kind of functionality with existing GPS modules, such as the popular NEO-6M, in a DIY electronics setup.
I've noticed that when a GPS module is hooked up to something like an Arduino, it can display latitude and longitude values fairly easily. However, converting that raw data into meaningful, human-readable information—like the name of the current city—seems to be more complicated. From my understanding, the my current city name tool might involve reverse geocoding, which takes latitude and longitude data and converts it into a readable location like a city name.
My question is: how would I go about integrating a reverse geocoding service into an electronics project that involves a GPS module? Specifically, what components or libraries could I use to retrieve the city name based on the GPS coordinates provided by the module? I assume there might be APIs involved, but I'm not sure how to implement this in the context of an embedded system like an Arduino or ESP32.
Moreover, would it be possible to store some kind of lookup table of city names and their corresponding coordinates directly on the microcontroller? Or would this require constant access to an external server for real-time data? I'm trying to figure out the most efficient way to get the my current city name functionality working without overly taxing the microcontroller or relying too much on external connections.
Has anyone attempted something similar with DIY electronics, and what challenges did you encounter? For instance, how reliable are GPS readings indoors, and could that affect the accuracy of retrieving the city name? Any advice on optimizing GPS modules for better location accuracy would also be helpful.
Looking forward to any insights or suggestions from fellow hobbyists who have worked with GPS in electronics projects!
Look at free location databases such as this:
Click on the "Entire world database" button and get the free database.
You would need to pack it in to such as an sqlite database and use a microcontroller with adequate storage for several megabytes of data.
With appropriate programming, you could find the nearest city to the current GPS location & give the bearing and distance if not within a reasonable distance of the city centre.
