Hi,I followed your circuit and I get around 3.7V for 1KG thing and 1.1V when there is nothing on the scale. I should short 1 pin of the variable resistor to the middle pin of the resistor right?Thank you![]()
Yes, connect one end of the pot pin to the centre wiper pin, see my earlier diagram.
You should also be able to reduce the 1.1V [ Zero pot] with no weight closer to 0V for Vout. this will make around +3V for 1Kg as I said earlier.. OK
E
