As for a method of building stuff, use the tried and true DIN rail construction technique. Search for DIN rail PCB holder. Also look at www.winford.com and here: www.asi-ez.com
You can see all sorts of building blocks. DIN rail is essentially an erector set for building of electronics controls. The bottom of a flange mounted enclosure has a 1/4" piece of aluminum in it. You tap a few holes for the rail and that's all you need. There are still reason to say tap holes to mount a transformer. Then for fun, you use wiring duct to route the wires. I did build electronics instruments using that method and it worked out well.
DIN terminal blocks might be hard to understand at first because one end is open. A block of terminals gets an "end plate". You secure the bunch with screw locked end stops. There are partition plates if you want to separate groups of terminals. The terminals have levels. You can buy jumpers for the terminals.
