Some farmers run their tractors from the gas produced by chicken droppings.
Dual-Fuel™ technology enables a heavy-duty diesel engine to operate on a high proportion of natural gas. Firstly, a Dual-Fuel™ engine is a diesel engine, unchanged in its basic thermodynamic operation. However, with Dual-Fuel™, diesel combustion is used only to ignite a metered charge of natural gas and air. A small injection of diesel is made to ignite the gas and air. This is called a pilot injection. The pilot injection is delivered by the standard, un-modified diesel injection system fitted to the engine. Once ignited, the gas and air charge burns rapidly and cleanly. By using diesel pilot ignition and retaining the diesel’s high compression ratio, the gas combustion can be achieved at very lean air-fuel mixture ratios. Known as “lean-burn”, this delivers high efficiency and low NOx emissions.
I actually know a guy who makes his own diesel from used cooking oil he gets from restaurants and take-aways in the area. According to him the drop in performance is big enough to actually feel it, he uses it mainly in his bakkie (pick-up truck), and also reports a real interesting smelling exhaust fume when sticking it.
I had a look at methane, it should make a good fuel, but can have some interesting challenges:
Melting point: -182.5 deg C
Boiling point: -161.6 deg C
Flash point: -188 deg C
Don't think I would like to spend all day in the sun on that tractor. Although it needs 4 to 5 times atmospheric pressure to burn, that could help the safety a bit, but then again 5 to 15% of it in air mixture is enough to take fire.
This substance really like to be a gas, other than some other drips.
Some logistics around methane, but doable.
It can be synthetically manufactured, but are also found in the earth's crust ( here and there), and abundantly on the ocean floor.
Now where is my scuba suit.......
Thanks,
I've read that, and this prof obviously has years experimentation and some decent funding behind him. The chap I'm talking about is basically unemployed, but rather good at working with his hands, if he wants to.
He also stated to me that getting his hands on the used cooking oil can be a pain, as some big companies actually pays to collect the old oil from these restaurants, etc.
Interesting, wonder what they do with it......
That brings me to another thing - storage of such volatile fuel, it should be possible to escape through some porous metals, or do you think not?
Hydrogen producing automobiles.
I was looking at the stuff that that guy sent me. From the drawings I think that they resemble the drawings from the above ads here on this site. Funny I have never noticed them until now. I'll bet dollars to donuts they are the same people hawking the same info.
I hope I can get that PDF stuff up here so you guys can pick it apart.
That's fine, I've been through so much, if you can stick it I'll take a look. I must admit, I'm not sure I'm a firm follower of hydrogen as combustible based propulsion, definitely used in fuel cells. But indications are methanol will outperform hydrogen in fuel cells, hearsay on my part.
I do not even take note of the buy a plan deal, to many unknowns therein. If someone has good practical knowledge they want to share, I listen, that's how I'm picking up what is out there, and who knows, maybe soon I can start experimenting with some ideas, a collaboration of what everyone says.
