MrAl,
I can't figure what your point is.
Isn't that what I said at the end of post #55?
I said very specifically in post #40 that -R[T] was the output impedance to the left of all three resistors on the right. So -R[T] is the output impedance of the transistor without any resistors connected to the collector terminal. If you want to include R[c], it should be obvious that a parallel calculation need to be performed. I should not have to define that every time I reference it. I am glad you agree that my method got the right answer.
I gave the equations, described what they stood for, and showed how to derive them in the narrative of the attachment of post #40.
Agreed, I call that the Applied Source Method. It is certainly very direct and valid. Others will have to decide whether the method you used or the GIT is less work.
To what end? We both know what R[in] and R[out] are now. The GIT method does not work for nonlinear circuits.
Ratch
If i say to you that:
"Rx is the output impedance"
Now i ask you again, what is the output impedance? If you dont know that it is Rx then you really need help
"Sure, but R[L] is not the unknown, it is a given. It is not used for the output impedance, but for the imput impedance."
but RL could be called the output impedance and then solved for explicitly and that's all that would be required. No parallel resistors later.
[assuming hie to be zero and calculating "-RT" and calling that equation the 'output impedance']
"Then that would be a failure in my method. Can you show that to be true?"
I dont think it was a failure in 'your' method, i just think you were originally taking RT (or -RT) to be the output impedance, then used that equation to to calculate the output impedance with hie equal to zero, or else you just used that equation.
To show that there is an error, all you have to do is take your 'new' equation (with the parallel Rc) and compute the 'output impedance', and it does not come out to Rf/(1+hfe) as you stated. That was another source of confusion because you were then explicitly stating that Rf/(1+hfe) was the 'output impedance' with hie equal to zero yet the only way you could get that result was if you used the equation for -RT for the output impedance. If you used your 'new' equation (which we now know is the right way) you would have found a little more complex result, not Rf/(1+hfe). If you have a problem with that, simply calculate the 'output impedance' using your new equation, which we now believe to be correct at least in the linear sense.
I just want to mention that when someone asks something like, "What is the value of Rx", the best way to show it, if you take the time to do it at all, is more or less like:
Rx=f(x,y,such_and_ such)
That why they can use their own method and come back and immediately calculate your result and compare to see if they made a mistake. If you instead come back with:
Ry=f(x,y,whatever) and state that is Rx, or even if you dont state that is Rx but is really Ry, that just makes it more difficult for them to calculate the real required value of Rx.
In other words, if they ask for input and output impedance why not just show expressions for that: Rin=f1(R1,2,3, etc.) Rout=f2(R1,2,3, etc.)
That would make it a lot clearer and easier and a lot faster too
BTW, the way i came up with the output impedance was using the standard output perturbation method. One of the simplest ways is to just use a current source on the output and calculate the voltage deviation and the current deviation and then take:
Rout=dV/dI
which of course is very straight forward.
Isn't that a bit trivial? How about one I already did at https://www.electro-tech-online.com...-thevenin-theorem-phasor-irwinext8-14.124126/ ?If you want to do a simpler example using GIT that you mentioned, that would be nice i guess. We can do a simple voltage divider with R1 on top and R2 on bottom fed by a voltage source Vs:
Vs o---R1---+---R2---o GND
where we take the output from the junction of R1 and R2. We want to calculate the input resistance and the output resistance (call it impedance if you like). This should be simple but lets see how it goes
Before we depart from the transistor circuit however i think we should clear up the equations a little. Make them into explicit equations for Rin and Rout.
Also, a non linear analysis using some Spice data would be very nice too, to back up the linear method.
Ratch
