theo92
Here, I've tried to design a Acoustic Guitar Piezoelectric preamplifier. I knew piezo electric preamps are not like conventional non-inverting differential amplifier because piezoelectric pickups are of very high impedance.
Although, I don't have any experience in designing a customized preamp, but I'll have to give it a try.
The circuit is basically a instrumentation amplifier. Gain is set by R6, which is: G = 1+(2R/R6), here R is 4.7K, so the gain here is G ≈ 14.8. in final design, I'll replace it by a 4.7K preset.
Next thing, I think it needs a DC blocking capacitor at input to pass only AC signals from the piezo transducer. Will I use a high pass filter there? like:
What should be the optimum C and R value so that the frequency response is not become too affected (specially the lower ones), what if, C = 1µF and R = 4.7KΩ, ie. signals below 1/(2*Pi*R*C) = 33.86Hz will cut off. Is there any wrong? Any other idea?
Will I need to add any capacitor in output? I think it's not needed because I'm using a split power supply, so I don't need a decoupling capacitor. Right?
Now in LTSpice, I've done it using LT1001, but in real world I'll do (I've done it in breadboard) it using TL072. Later I'll be using TL074 to save space a bit. Will NE5532 outperform TL07x in this application? (oh! again the classic TL072 vs NE5532 battle)
Please tell me some other improvement options.
