Interview questions
Hi, i've been asked today few questions but i were suspecting of the answers
1. what is the difference between RC circuit and RC with an op-amp ? i said the gain , he said suppose its 1 , he answered that in the RC-op-amp the capacitor will charge lineary , is this correct ??
2. what's the difference between butterworth and cheybychev filters ?
3. what happens when there are ripples in a low pass filter circuit in the pass band area ??
An RC with an opamp is an active filter, it can maintain the original voltage levels of the signals with only the filtered frequencies being lower. A passive RC filter is going to have loss in amplitude even at the unfiltered frequency.
A butterworth filter has flat frequency responce, the chebyshev filter has ripple in the passband.
When there's ripple in the passband it's not ideal so your frequency response will not be flat like ideally you would want it to be.
So he is wrong when he said the difference between active and passive filter ?? he said , the cap will charge lineary ..
and he said about the ripples that , the gain will be different at different ripples , is this correct also??
I didn't say he was wrong, there's more than one reason why active filters are better. You'd have to provide circuit examples to comment further, and yes the ripples will produce different gains at the given frequency.
Really need more information here, as this depends on what you're discussing. For a first order filter, there is very little difference. If it's a linear integrator, then the active integrator will see the capacitor charging linearly, as opposed to the passive integrator.
Butterworth filters are an extension to higher orders of the first order RC or RL LPF. The poles of the Butterworth characteristic are equally spaced around a circle. The Chebychev characteristic derives from the Chebychev Polynomials: C(x)= cos(Karccos(x)). The poles are arranged around an ellipse.
This is usually accompanied by sharp skirt selectivity and a nasty, nonlinear phase characteristic. (I.e. Chebychev or Elliptic filters. You wouldn't want to use it where fidelity is the goal.
The capacitor in an RC integrator circuit that uses an opamp charges linearily. Look up integrator circuit in Google.
A capacitor charged by a simple resistor charges exponentially.
Thank very much for the reply. I want share some my interview quesitions. I hope it's useful.
We also find them more same at: **broken link removed**
Rgs.
