What is a "line supply"?No sir, i want maximum value of the line supply
if your electricity is 220VAC then a load of only 1.5 ohms causes a current of 230/1.5= 146.7A.as my teacher told that it depend on load resistance as the resistance decrease the will be infinite that i wan to conform how it possible as if load is of 1.5ohm so, the will be 146amp is this possible..!
Sir, I want to calculate current of ac house line supply not of Battery...!
The AC Suppy of a House Circuit is Determined by the House Fuses of your Electrical Box.
On our 110-220 AC Lines, Most Outlet Lines in North America are rated at 15 Amps.
Hot Water and Dryer Lines are usually 40 Amps, and the Main Fuses are typically between 60 and 200 Amps.
Not Sure What your Voltages or Fuse Ratings are Where you live? But Just LOOK at the Fuses or Circuit Breakers in your Main Electrical Box.
if we connect no fuse and then we find max. current, i thick the supply coming in house have some rated current as it come from transformer so, how can it be possible to have current like 146amp if we see an example like battery it has max. current rating on it and can't be increase by decreasing load, pls clear my doubt.
But WHAT IS THE POINT TO THESE SILLY QUESTIONS?
Pls clear my one more doubt as every one say DC is more harmful then AC why we get shock in ac but when we simply touch both terminal of dc we can't get shock,why...?
here in indonesiaHere in india power outages are very common... Typically every household invariably in any city all thru the country faces 2 to 3 hours of outage daily.. Simply because we dont have sufficient generators to feed all people... So they shed loads in turns.. Power from a generator for one place in morning and for some other place in evenings...!
@audioguru: I am surprised to know that its a surprise for you...!![]()
i have diode Fr2007 i have solder it out from ups i searched in google, but not get it link pls tell what is this..?
In 5kw ups if we connect 50 watt load that mean it will continue for 100hrs. is this true pls clear my doubt.
625VA might be the max allowed momentary peak output power. Its continuous allowed output power might be only 300VA.I have 625VA UPS for computer, but if i calculate it power given by battery to ups is P=12*(less than 20amp.) how can it give power output of 625VA As 625=220*I(amp).
