Gandledorf
I'm working with a circuit where I'd like to have a battery low charge indicator signal (to either drive an LED, or alert a uC of impending power problems so it can clean up, flash a warning and power off.
The problem is, I'm only an electronic hobbyist, and have only four credit hours (two labs, Analog and Digital) in EE. Most of my experience is CS. I simply have no clue how to design such a circuit. The biggest problem is that I have only a single power source (6V battery pack connected through a 5V regulator circuit) to work with... How do I compare this voltage? I'd like to be able to trigger when I start dropping below 5V, so I don't end up with a system powering down unexpectedly.
Additionally, if I want longer life for my system, would it be enough to build another 6V battery pack and connect them in parallel to the circuit?
