It was 50 Ohms. I used to use the same RG58 cable for that and for RF connections.Coaxial cable used to be commonly used for networks, it used BNC plugs, and t-connectors at each PC, with 75 ohm terminating loads at either end.
It's a VERY long time since I've seen anyIt was 50 Ohms. I used to use the same RG58 cable for that and for RF connections.
There are a goodly number of different sized F-connectors, you need to buy the correct ones for the cable you have - the right size ones are probably better than crimp-on ones (which also come in different sizes as well).
Then don't buy crap from the dollar storeThe Dollar Store only had the one size.
Maybe Poundland has betterThen don't buy crap from the dollar store![]()
Well you'd be paying more anywayMaybe Poundland has better
Or even better, just apply self-amalgamating tape over the plug - standard procedure for outdoor connections.In addition to getting the right size connector for the cable, you also should choose a weatherproof version if you want reliable operation outdoors.
The simple screw on, or even crimp types don't prevent water from getting into the cable end.
Here is one for RG-6. https://www.amazon.com/Klein-Tools-VDV812-623-Compression-Connectors/dp/B008C7ZCI8?th=1
