I have a 24v latching solenoid. If you apply 24V to it, it immediately fires the bolt, and will stay that way even when the power is removed. If you apply reverse polarity 24V it will withdraw the bolt and stay that way with the power removed.
The problem I have is that I want to have it 'lock' and 'unlock' off another circuit, but it uses a keyswitch that is either always on or always off.
So basically when the switch is turned on, I just want to pulse a relay that has the solenoid attached to it, but relays seem to only be available that stay closed whilstever they are getting power. Is there a relay that will just click on momentarily (less than 2 seconds say, or as fast as 200ms) when power is applied?
