Anonymous321
I was worried you were gone there for a sec, even though you were online.
There are blue lines connecting springs. But those are just labels that were part of the box. You can ignore them. The labels mean nothing.john1 said:can you tell me what the blue drawings are under the springs .....
Or is there really nothing there ... ?
The spring where the red wire goes down to the -ve of 9V is the emitter. The spring where the red wire goes to the -ve of the siren is the collector. The other silver thing going up to the spring with no red wire coming/going from it is the base.john1 said:Okay, so there arent components and stuff underneath, its just labels on the box.
The transistor in that last pic,
cant quite see which leg goes where ....
Only the transistor and the 9V battery clip are placed according to the labels on the box. The siren (and the wires coming to it) are in the resistors section.john1 said:I take it that its placed as per the blue drawing , yes ?
No siren. No voltage.john1 said:Okay.
stick your voltmeter across the siren connections,
and connect the battery briefly, then disconnect the battery.
Any siren sound ?
Any voltage show on the meter ?
Yes, it is. I'm a little afraid that it may be busted from so much previous use. So I might just pluck in another one.john1 said:Just to check,
the transistor is the NPN type, yes ?
Ok, I won't. Oh ok.john1 said:no, dont change anything
The closest one I have is 33k. Should it be 1/4 or 1/8 watt?john1 said:could you now pick a resistor, around thirty K please.
Haha yeah. Instant messaging.john1 said:Ha,
my last post crossed with yours,
and i thought for a minute you were going to pull it apart!
When i edited, i saw you noted my post before i edited !
