LCD1602/2004 via I2CBus with PCF8574 (Oshonsoft Basic).
DogFlu66
I found it interesting to have the possibility of controlling the classic 1602 LCD (two lines with 16 characters each) using just two wires via the I2C bus. I noticed that there are kits available that include the 1602 LCD along with an adapter board featuring an integrated circuit called the PCF8574. This chip is an 8-bit I/O expander that can function as both inputs and outputs, and communication with it is carried out via the I2C protocol.
By connecting this chip to the microcontroller through the SDA and SCL lines, along with the two power supply wires, the LCD can be fully controlled. To achieve this, I have developed a library that manages the 1602 LCD using a 4-bit data bus and 2 control bits. I then integrated it with a library I previously wrote to control the PCF8574, resulting in a complete solution to control the 1602 LCD via I2C communication.
It is essential for the microcontroller to have an I2C module and to use the previously developed library for handling it. I am providing all the necessary files for anyone interested in experimenting with it.
Functions Overview (Lcd1602_I2CLib.bas):
LCD_Init()
Initializes the LCD in 4-bit mode, no cursor, 5x8 dots.
Sends the necessary startup commands and prepares the LCD for operation.
LCD_DefChar(CharIndex As Byte, CharMask_7 As Byte, CharMask_6 As Byte, CharMask_5 As Byte, CharMask_4 As Byte, CharMask_3 As Byte, CharMask_2 As Byte, CharMask_1 As Byte, CharMask_0 As Byte)
Defines a custom character in CGRAM.
Allows the user to create a custom character by specifying 8 bytes of pixel data.
LCD_PosXY(x As Byte, y As Byte)
Positions the cursor at a given (x, y) coordinate.
Sets the position on the LCD screen based on row and column values.
LCD_PutC(char As Byte)
Displays a single character on the LCD.
Sends an ASCII character to the current cursor position.
LCD_CursorBlink(sBit As Bit)
Enables or disables the blinking cursor.
Controls the visibility of the blinking cursor based on the input bit.
LCD_Cursor(sBit As Bit)
Turns the LCD cursor on or off.
Enables or disables the display of the cursor.
LCD_BackLight(sBit As Bit)
Controls the LCD backlight.
Turns the LCD backlight on or off based on the given bit value.
LCD_Out(line As Byte, pos As Byte, char[20] As String)
Prints a string on the LCD at a specified line and position.
Outputs up to 20 characters starting at the specified position.
LCD_Line1Home()
Moves the cursor to the beginning of line 1.
Resets the cursor to the home position on the first line.
Function LCD_Line2Home()
Moves the cursor to the beginning of line 2.
Resets the cursor to the home position on the second line.
LCD_Line1Pos(x As Byte)
Sets the cursor position on line 1 to the specified column.
Moves the cursor to a specific position on the first line.
LCD_Line2Pos(x As Byte)
Sets the cursor position on line 2 to the specified column.
Moves the cursor to a specific position on the second line.
LCD_Line1Clear()
Clears the first line of the LCD.
Removes all characters from line 1.
LCD_Line2Clear()
Clears the second line of the LCD.
Removes all characters from line 2.
LCD_Clear()
Clears the entire LCD display.
Erases all displayed characters and resets the cursor to the home position.
Note: new version of the library can now work with 1 to 4 line LCDs (2025/01/30).
Just as a side note on this.. One of our former members did something miraculous using
two wires and a shift register. I used it quite a bit.
members name K8LH
members name K8LH
Easily done, and essentially the same thing - the problem is it's not I2C - the I2C version means you can have multiple displays connected using the same two pins, plus any other I2C devices you might be using. With the shift register version you need more than two pins once you go past one display.
I once had four (different sized) LCD displays connected via I2C, plus a DSxxxx clock module, just because I could :D
Have done a project turned a PIC18F14K22 slave into a back pack for an LCD, Host can send commands over I2C for size ( 1x8 to 4x20 ) ascii text, position,cursor on off, back light on off, spare pins had three traffic light LEDs saves a lot of code on the host.
I emailed with Vladimir recently and he is planning on adding the I2C LCD to the Compiler and Simulator in April. The Simulator model will be a huge addition, similar to the parallel version that is now available.
I've expanded the function to control 1602 or 2004 LCDs via I2C (PCF8574) with the ability to generate large numbers. I've attached the modified library and necessary files, along with a screenshot of the LCD.
Hi, I'm interested in testing the libraries to use a 1602 LCD display with the PCF8574 module.
I'm going to use a PIC18F4550. I'm new to loading libraries. I understand that I would have to modify _I2CLib.bas and change the pins. In my case, it would be like this: ' I2C Pin
Symbol I2C_IO_SCL = TRISB.1
Symbol I2C_IO_SDA = TRISB.0
And from my program, I include the libraries.
Include "Lcd1602_I2CLib.bas"
Include "_I2CLib.bas"
Can you guide me on how to do this? I'm missing something because I get errors in the libraries when I compile. If you have an example, I'd appreciate it. Another question in the IDE manual
Does this exist?
Interfacing character LCDs using PCF8574 I2C I/O expander
LCD_MODE lcdPCF8574 lcdPCF8574A LCD_SDA LCD_SCL LCD_ADDR LCD_BL lcdPCF_BLlow lcdPCF_BLhigh
How can I use this? Do I need to download any libraries? Or how does it work because it doesn't recognize the commands? Sorry, I'm very inexperienced with this. Thanks.
You no longer need external libraries to interface the LCD1602/2004 via I2C with the PCF8574 port expander, since native support was introduced in IDE v5.83 and optimized in the latest update (v5.84). Below is the link where you can follow the full discussion.
If you prefer to use the libraries using the MSSP module in I2C mode which is more efficient and faster:
I’ve adapted the libraries to work with PIC18F devices (which only have a single MSSP module) and renamed “DATA” —a reserved word in the PIC18F4550— to “_DATA” to ensure compatibility.
