Learning to write a function
GreyHairOldGuy
I feel pretty dumb - you guys are obviously so far above me in programming........
..........I got my printout in hex working, thanks to Ian and others.
My first approach was VERY crude, but it worked.
I would really appreciate some ideas on how YOU would do it.
ALSO
I am now trying to create my first function and after working on it all day, I am still stuck on the first line.
I come in with an 8 bit byte and leave with a 16 bit word.
I can either define the byte or the word but cannot seem to figure out how to define both.
(Please promise not to laugh) My code is below:
'FUNCTIONS - FUNCTIONS - FUNCTIONS - FUNCTIONS - FUNCTIONS
Function hextodsp(wout As Word) As Word, (binx As Byte) As Byte
Dim xhi As Byte
Dim xlo As Byte
xhi = binx Mod 16
If xhi = 0x0 Then wout.HB = 0x30
If xhi = 0x1 Then wout.HB = 0x31
If xhi = 0x2 Then wout.HB = 0x32
If xhi = 0x3 Then wout.HB = 0x33
If xhi = 0x4 Then wout.HB = 0x34
If xhi = 0x5 Then wout.HB = 0x35
If xhi = 0x6 Then wout.HB = 0x36
If xhi = 0x7 Then wout.HB = 0x37
If xhi = 0x8 Then wout.HB = 0x38
If xhi = 0x9 Then wout.HB = 0x38
If xhi = 0xa Then wout.HB = 0x41
If xhi = 0xb Then wout.HB = 0x42
If xhi = 0xc Then wout.HB = 0x43
If xhi = 0xd Then wout.HB = 0x44
If xhi = 0xe Then wout.HB = 0x45
If xhi = 0xf Then wout.HB = 0x46
xlo = binx / 16
If xlo = 0x0 Then wout.LB = 0x30
If xlo = 0x1 Then wout.LB = 0x31
If xlo = 0x2 Then wout.LB = 0x32
If xlo = 0x3 Then wout.LB = 0x33
If xlo = 0x4 Then wout.LB = 0x34
If xlo = 0x5 Then wout.LB = 0x35
If xlo = 0x6 Then wout.LB = 0x36
If xlo = 0x7 Then wout.LB = 0x37
If xlo = 0x8 Then wout.LB = 0x38
If xlo = 0x9 Then wout.LB = 0x38
If xlo = 0xa Then wout.LB = 0x41
If xlo = 0xb Then wout.LB = 0x42
If xlo = 0xc Then wout.LB = 0x43
If xlo = 0xd Then wout.LB = 0x44
If xlo = 0xe Then wout.LB = 0x45
If xlo = 0xf Then wout.LB = 0x46
End Function
You seem to be wrongly using the function statement, try this example.
Dim wout As Word
Dim your_byte_in_here As Byte
main:
For your_byte_in_here = 0 To 255
wout = hextodsp(your_byte_in_here)
Next your_byte_in_here
Goto main
End
Function hextodsp(binx As Byte) As Word
Dim xhi As Byte
Dim xlo As Byte
xhi = binx Mod 16
If xhi = 0x0 Then hextodsp.HB = 0x30
If xhi = 0x1 Then hextodsp.HB = 0x31
If xhi = 0x2 Then hextodsp.HB = 0x32
If xhi = 0x3 Then hextodsp.HB = 0x33
If xhi = 0x4 Then hextodsp.HB = 0x34
If xhi = 0x5 Then hextodsp.HB = 0x35
If xhi = 0x6 Then hextodsp.HB = 0x36
If xhi = 0x7 Then hextodsp.HB = 0x37
If xhi = 0x8 Then hextodsp.HB = 0x38
If xhi = 0x9 Then hextodsp.HB = 0x38
If xhi = 0xa Then hextodsp.HB = 0x41
If xhi = 0xb Then hextodsp.HB = 0x42
If xhi = 0xc Then hextodsp.HB = 0x43
If xhi = 0xd Then hextodsp.HB = 0x44
If xhi = 0xe Then hextodsp.HB = 0x45
If xhi = 0xf Then hextodsp.HB = 0x46
xlo = binx / 16
If xlo = 0x0 Then hextodsp.LB = 0x30
If xlo = 0x1 Then hextodsp.LB = 0x31
If xlo = 0x2 Then hextodsp.LB = 0x32
If xlo = 0x3 Then hextodsp.LB = 0x33
If xlo = 0x4 Then hextodsp.LB = 0x34
If xlo = 0x5 Then hextodsp.LB = 0x35
If xlo = 0x6 Then hextodsp.LB = 0x36
If xlo = 0x7 Then hextodsp.LB = 0x37
If xlo = 0x8 Then hextodsp.LB = 0x38
If xlo = 0x9 Then hextodsp.LB = 0x38
If xlo = 0xa Then hextodsp.LB = 0x41
If xlo = 0xb Then hextodsp.LB = 0x42
If xlo = 0xc Then hextodsp.LB = 0x43
If xlo = 0xd Then hextodsp.LB = 0x44
If xlo = 0xe Then hextodsp.LB = 0x45
If xlo = 0xf Then hextodsp.LB = 0x46
End Function
Thank You
I see what you did - the function name hextodsp is actually the output word, or at least contains it.
Using 32 "If" statements is dumb, but was a first pass at the problem and it worked.
What is a better way?
Mike
Use LookUp function.
hextodsp = LookUp ( 0x30, 0x31, ... 0x41, ... 0x46 ), x
where x is 0 to 15
A much simpler and efficient way would be,
if x<0x0a then
    hextodsp.HB = 0x30+x
else
   hextodsp.HB = 0x41-10+x
Sudo code as I don't know oshonsoft syntax.
if x<0x0a then
else
endif
Good enough!! Just an endif to add!!
Based on the OP's original function this is what I did.
Dim xhi As Byte
Dim xlo As Byte
xhi = binx Mod 16
hextodsp.HB = 0x30 + xhi
xlo = binx / 16
hextodsp.LB = 0x30 + xlo
End Function
Dim xhi As Byte
Dim xlo As Byte
xhi = binx Mod 16
xlo = binx / 16
End Function
Wrong way round.... The OP wants to display a hex value not binary to ASCII... No division needed, As Mike has already shown we need ASCII A~F as well...
Wow!
I want to look at and try your other suggestions as well, because if nothing else, I'll learn something useful for later.
THANK YOU very much everyone for helping me learn how to do this.
My one quick question - is there a line continuation character in Oshonsoft? I think I looked EVERYWHERE.
Another package I used to use allowed _ to be used as a line continuation but it didn't seem to work for me here.
This is what I came up with - I did 8 to 16 and 16 to 30 bit Hex to ASCII conversion Functions:
'Function h8to16a
'Input hex2 Two Hex Characters total 8 Bit BYTE
'Output h8to16a Two ASCII Characters total 16 Bit WORD
Function h8to16a(hex2 As Byte) As Word 'Define Function
Dim tmp As Byte 'Temporary Storage for High/Low Hex Digit
tmp = hex2 Mod 16 'Extract Lower Hex Digit
h8to16a.HB = LookUp("0123456789ABCDEF"), tmp 'Convert to ascii & Store Upper
tmp = hex2 / 16 'Extract Upper Hex Digit
h8to16a.LB = LookUp("0123456789ABCDEF"), tmp 'Convert to ascii & Store Lower
End Function
'Function h16to32a
'Input hex4 Four Hex Characters total 16 Bit WORD
'Output h8to16a Four ASCII Characters total 32 Bit LONG
Function h16to32a(hex4 As Word) As Long 'Define Function
Dim txp1 As Byte 'Temporary Storage for the Hex Digits
Dim txp As Byte 'Root Temporary Storage for the Hex Digits
txp1 = hex4.LB 'Get Bottom 8 Bits-------------------
txp = txp1 Mod 16 'Extract Lower Hex Digit
h16to32a.4B = LookUp("0123456789ABCDEF"), txp 'Convert to ascii & Store Lower
txp = txp1 / 16 'Extract Upper Hex Digit
h16to32a.3B = LookUp("0123456789ABCDEF"), txp 'Convert to ascii & Store Lower
txp1 = hex4.HB 'Get Upper 8 Bits---------------------
h16to32a.HB = LookUp("0123456789ABCDEF"), txp 'Convert to ascii & Store Lower
h16to32a.LB = LookUp("0123456789ABCDEF"), txp 'Convert to ascii & Store Lower
End Function
Merry Christmas everyone............Mike
