audioguru said:Can you beg, borrow, steal or make a CMOS or 555 variable frequency square-wave oscillator to feed it then?
Test it without the engine running.
Hehe.. i assume u didn't see my message above posted 2 minutes before yours.
anyways...to recap, i fixed the problem, dirty Vcc, ignition.. changed to battery and it was all dandy.
however, i was wondering if you know a good way to regulate voltage in this case - as i use a LM741 with a resistor voltage divider network to get a voltage to compare to. when the loads are turned on, ths incomign Vcc 12v supply fluctuates, changing the shift point along with it.
in other words, when the air-cond/loads are turned on, the alternator produces more voltage, instead of 12v, it goes up to about 13.3++..that difference is what i mean.
any luck?
thanks!
