Samsontimi
Please can anyone help me with FM Transmitter circuit that will cover a town of about 10000 meters?
I'm guessing he already has that and he just needs a diy 5kW transmitter. Questions about the power supply and antenna will come in future posts.You must have a license to operate a radio transmitter, the transmitter circuit must be certified not to cause interference by its harmonics then your government will provide you with your own frequency.
usually, if he's a legit broadcasting station, he would need not just a license, but a construction permit as well, and wouldn't be asking how to build one, as commercial broadcast equipment is something a station usually buys, not builds from scratch. one of the reasons for that is that it has to pass regulatory compliance testing, and the equipment manufacturers that supply broadcast equipment have already jumped through those hoops so the broadcaster only needs to verify the equipment is operating properly rather than navigate through the expensive and time consuming compliance testing jungle required for newly designed transmitters.
Have any of you noticed the original poster is not a part of this conversation? Asking for a friend.
Seems a pretty poor 'guess' - I imagine you really are 99% confident that he DOESN'T have a licence, and is unlikely to be able to get one!.
Not sure if you are all incorrect.... You can freely buy a Lora module from many shops.. These are capable of 20K with decent aerials.
Adafruit Rfm96W LoRa Radio Transceiver Breakout - 433 Mhz - 3073
If you're looking for a simple way to send data over long distances, the Adafruit LoRa Transceiver Board 433 MHz could be just what you need. LoRa is short for Long Range Radio. Designed primarily for M2M and IoT applications, it won't send data fast but it will send it far - up to 2km line of...www.okdo.com
Then the OP should have stated it was a Broadcast.. Doesn't mention DIY FM transmitter..But has no relevance to this thread?
No, it's serious offence!.
There are too many noobs coming here from countries without any laws about radio communications.
