blueroomelectronics
It does look magical.
That was one of the reasons I did my own board.3v0 said:The thing would be a lot easier to debug if the RB6-7 were dedicated to the debugger. If I lay this thing out again I will move the switches down to RB0-3 and add the pullup resistors.
Pommie said:Those bulbs look excellent. I expected them to look a bit naff. Guess I'll be buying some food dye tomorrow. What is a common use for the clear acrylic spray and where might I buy it, model shop?.
blueroomelectronics said:The reason for the switches on RB4-7 is wake up on port change. You also get an easy to use interrupt if any of the switches are moved. The ICD will have no problem with the switches just make sure they are open when programming.
blueroomelectronics said:The 16F628A doesn't have debug anyway.
Microchip does make an ICD version of the chip on a header for about $24. I've used the 12F675 version with my Junebug and a small PCB header.
blueroomelectronics said:Then the 16F88 will work like a charm, debug mode will disable RB6 & RB7 (read 0) You should be able to test your code with the remaing two switches.
Yes, I've got the trace option 16K3v0 said:It does.
Does thet ICE provide trace?
