Is anybody familar with the design of the MC34063 1.5A, Step-Up/Down/Inverting Switching Regulator.
References:
https://www.electro-tech-online.com/custompdfs/2008/11/MC34063A.pdf
https://www.electro-tech-online.com/custompdfs/2008/11/AN920-DPDF.pdf
I am using solar panels and 20A solar charger for charging of batteries, which is connected to a 12v-240v invertors to power lighting & appliances I require.
Being an electronics hobbiest, im designing a few handy circuits direct from the 12v battery output to power my projects.
I need a 12v to 5v @ 890mA step-down using the MC34063. I'm not familar with some of the values required for the MC34063 design. Here are my values:
Voltage Input (MAX): 13v DC
Voltage Input (MIN): 11v DC
Voltage Output: 5v DC @ 890 mA
MC34063 Values I have used for calculations:
I_OUT = 890 mA
Freq = 33 khz (the typical value used in the spec MC34063)
V_Ripple = 25 mV (p-p) (0.5% * Voltage_Output) used in similar 12v-5v designs
V_F = 0.8 (as per Step-Down example in AD920/D)
V_Sat = 0.8 (as per Step-Down example in AD920/D)
With the above values, here are the component values I get:
CT = 640pF
L = 47uH
RSC = 0.13 ohm
CO = 269 uF
I have calulated the following 2 possible values for R1 and R2, giving 5v:
R1 = 1k, R2 = 3k ie. 1.25*(1+3/1) = 5 OR
R1 = 1.2k; R2 = 3k6 ie. 1.25*(1+3.6/1.2) = 5
Where; R1 is connected to ground to Pin 5 (comparitor input).
See Figure 10 on the MC34063 spec for the component placement.
I would appreciate anybody that has had any design work with the MC34063, to check my component values.
Im not sure if the Freq, V_RIPPLE, V_F, V_SAT values used are correct or not.
I have noticed using the above figures, the IPK_SWITCH calculation resolves to 1780mA, which is above the 1500mA maximum?? Or is this referring to the maximum output (ie. I_OUT) at 1500mA?
References:
I_OUT = 890 mA
CT = 640pF
L = 47uH
RSC = 0.13 ohm
CO = 269 uF
