Hey guys,
I've been having trouble trying to do an extremely simple amplification setup for a microphone hooked up to a breadboard.
I'm using a 741 op amp with basically the simplest non-inverting setup possible:
With 1 kohm for R1 and I've tried a few values for R2. But the output of the amplifier stage is just nothing when I hook the input up to the mic. The mic outputs pretty low voltages, but whether I use a lower (27 kohm) or higher (100 kohm) value for R2, nothing shows up at all.
If I use a function generator as the input, if R2 is too high I see a lot of railing or distortion in the output. The 27 kohm produced about 25X (very rough measurement) amplification so that's close to what it should be. Higher R2s don't seem to produce more than 20x amplification and that's with all the distortion.
So: theoretically, the amplification factor is 1 + R2/R1. Did I make bad choices in selecting R1 and R2? Why does the distortion occur with the function waveform generator input, and why doesn't anything output when I try connecting to the microphone?
Much thanks...it just seems theoretically, it's fine (if simple), but there must be things I am completely not considering.
![131-300px-Op-Amp_Non-Inverting_Amplifier.svg.png](http://static.electro-tech-online.com/imgcache/131-300px-Op-Amp_Non-Inverting_Amplifier.svg.png)
