With the sensor (and battery) disconnected, what resistance do you get between the two connector terminal on the harness side?
An with it disconnected but battery on, do you still get 2.5V on both terminals?
It is possible the input amplifier uses a "virtual earth" configuration, feeding current back through the sensor to cancel out the voltage whilst still amplifying the signal.
It's also possible that the sensor cable or the ECU input has a short.
