Hi guys this is my first Schematic to PCB convertion project can anyone please let me know if I did this right here is the link **broken link removed** but how do I atach the brd file from eagle.
Thanks guys your help is greatly appreciated.
Sammy
OK I turned it into a jpeg file hopefully this works. When you see the plan you will notice that where the speaker connector is suppose to be I just left it with 2 wires and I can attach a wire from a 3mm audio (walk-man etc etc.) and the LED it would of been clearer if I turned the LED 90 deg.
Sammy, your circuit is too simple. The LEDs will look like a dim blur without my peak detector circuit or one of the ones in the datasheet.
Your input capacitor is probably not needed.
Thanks audioguru what I did was put this circuit on the breadboard and it worked alright and it beats to the music but just like you said the leds are kinda blured. So you think I can get rid of the capasitor and it will work better?
A peak detector circuit at the input will make it better to see and make every LED light at the same brightness.
Your input capacitor is probably doing nothing and can be removed without changing how the circuit works.
The circuit is designed so that a peak input voltage of only 1.25V lights all LEDs when the level control is at maximum. The 1k resistor sets the current in the LEDs at only 11mA. If the current is set higher then the IC will get too hot (because your supply voltage to the LEDs is too high) since there is no resistor to share the heat.
