Hi Guys
the course work is required to design a project such that LED5 is driven by a PWM signal that causes the intensity to increase from a minimum to a maximum over 1 second then reduce back to zero over the next second repeats continuously’.
Even though I was try several times , the LED5 cannot reduce back to zero over next second. Please explain and give some idea to modify it.
cheers
cheers
#include <xc.h>
#pragma config WDTEN=OFF, FOSC=INTIO67,MCLRE=EXTMCLR,IESO=OFF, LVP=OFF
#define _XTAL_FREQ 4000000
void init(void);
void init(void)
OSCCON=0b01010010;//this to select internal osc at 4MHz
ANSELC=0x00;//make PORTC digital I/O
TRISC=0x03;//set appropriate data direction bits
PORTC=0x00;//clear any PORTC outputs
ANSELB=0x00;//make PORTB digital I/O
TRISB=0x01;//set appropriate data direction bits (RB0 is input)
PORTB=0x00;//clear PORTB outputs
TRISA=0b00000001; //all outputs except RA0 analogue IP
ANSELA=0x01; //make PORTA digital I/O except RA0 analogue
PORTA=0x00; //clear all PORTA digital pins
void init_PWM(void)
PR2=254;
T2CON=0b00000101;//enables TMR2 hardware and prescalar to 4
CCP1CON=0x00; //enables PWM
CCPR1L=PR2/2; //sets equal ON/OFF time
void main(void)
init();
init_PWM();
while(1)
CCP1CON=0x0C;
PR2=254;
while(PR2>=0)
PR2=PR2--;
__delay_ms(2);
__delay_us(168);
__delay_us(168);
__delay_us(168);
__delay_us(168);
CCP1CON=0x0C;
PR2=0;
while(PR2<=254)
PR2=PR2++;
__delay_ms(2);
__delay_us(168);
__delay_us(168);
__delay_us(168);
__delay_us(168);
