I'm trying to run a neon sign on a battery power bank.
The Neon is a custom sign comparable in size to bar wall beer sign or open sign. It's in a location where there isn't power supply without tripping over a wire.
1. Neon sign works when plugged into wall.
2. Neon sign turns on about 3 seconds then turns off with power bank attached.
I'm assuming the power bank has a fault trip that is turning off the circuit. Or is can the transformer suck enough power but once it is sent there it hasn't enough constant power? Do I need a bigger brick? Is the Neon sign sending out a ground that trips off the stand alone battery? If so then I splice the ground from going into the power bank and send it into a natural ground. My mind is turning and all I want is this neon sign to glow in the middle of a room. Any helpful input would be greatly appreciated.
A constraint for the power source, has to be about the size of a laptop or smaller.
