tim_the_toolman
I am trying to figure out how to create a circuit that will monitor voltage in DC (automoile) from 0 volts to an adjustable point, say 5 volts, and display the voltage in a LED display. But also trigger a relay for a add-on accessory at a given voltage. I have come across the tech sheet for the LM3914 IC and it looks like I may be able to use the chip to aid in my creation but I need a little guidance. Can I make the bar graph adjustable with a pot or somthing? Where in the circuit would it go? Does this chip need separate power ( which would be 11-15 vdc by the way )? Would the LM3915 be more suited? How can I set the trigger point for the relay, or is that a separate circuit all together? Please help
