Good suggestions, thanks! I'm not sure if you can see in the pic but I took three of the black wires and soldered them to the ground post on the plug where my power comes in. Will that be good enough? It didn't work at all until I did that. Grounding is something that has always been a bit confusing for me, I don't know why it just has been. Here's a pic of where the plug is mounted on my cigar box. Sorry, it's not the best angle for seeing how I have the bundle of wires soldered to the plug.
I was merely concerned with electrical safety. I am not very experienced with it since I don't do much high-voltage stuff (high voltage being AC mains). But from some of the reading I did... the 3-pronged plugs have Hot, Neutral, and Earth (ground). For an appliance, your electrical power comes from the voltage difference between Hot and Neutral. The Earth connection is a safety connection which also provides a safe 0V reference point. Basically, if you have an electrical appliance with a metal chassis, you NEVER want the metal chassis to be at a high voltage if something inside it fails - otherwise someone would come along, touch it, and die, or get seriously injured. So what is done is the Earth prong is always connected straight to the chassis of the device. This way, if something happens, and for example the Hot lead frays or the insulation melts, and it touches the chassis, it will get shorted right to ground and blow the circuit breaker in your house. If the Earth connection was not there, the chassis would be at the same voltage as Hot and your house fuse would not blow. That is, until a person or object touched it and became the conductor to ground... but then its too late.
I think since you have a wooden box, though, that this would not be an issue. If something inside touches the wood, the box does not assume that voltage because it is an insulator.
Then the Neutral just gets connected straight to Earth, like I think you did, to give things a 0V reference compared with other household appliances.
Now, those 3 black wires. Were they from the OUTPUT side of your ATX supply? i.e., are they the black wires that used to be in the motherboard plug and molex connectors?
While it is SAFE to make the connection between your black 0V output wires to EARTH (its not safe to connect them to Neutral or Hot), I am not sure why this caused everything to work. Usually these outputs are floating.
It is possible that your particular ATX power supply was designed so that something on the output side referenced Earth though. If this is the case, the connection was probably made by a screw through the PCB connecting to the metal chassis (which was connected to earth) to some trace on the PCB that the screw also went through. If so, when you removed the metal chassis, you broke this connection and caused something not to work. By completing the connection by connecting those 3 black wires, everything is back to how it was designed. This is what seems likely to me, but without a full schematic of the ATX supply its impossible to know what the designers did for sure.
I guess what attracts me to using the atx unit is having several different voltages to choose from. Am I missing something with laptop ps or what? What do you do if you need + and - 5v for logic and 12 for a motor or something at the same time? I know there is a reason as you know way more about this than I do, but I'm confused.
I think what he did was have several different supplies if he needs more than one voltage rail. If you need different voltage values and you don't have the right supply, there are circuits you can build that will change it to what you need. One such circuit involves an IC he mentioned, the LM7805. It is a linear voltage regulator, that will output a pretty solid 5V even if the input is 24V. You can also make them adjustable, to output any voltage you want between 0 and about 22V, given a 24V input.
I am having one other issue, the indicator led on my switch isn't working. The package the switch came in didn't have any info about how to hook it up. I used my meter and found which two were for the switch and I assume the third one is to supply the led. I'm afraid I might cook the light so I've been afraid to hook anything up to it.
Do you have a part number and manufacturer for the swithc, or a link to the page you bought it from? Even some info from the name of the part, like "common anode LED," whether the LED is red or blue or white or whatever, things like that. Cant really tell from your pics, is it something like this?
SPST 10A 12VDC Illuminated Push Button Switch with Red LED - RadioShack.com
I seriously need to learn how to use resistors and such. I have a very basic understanding of Ohm's law but I mean basic in the truest sense of the word. One of the things that I've never really understood is whether resistors change voltage. For instance, if I have a 12 volt supply and I need 9v at .5a how do I get it? With the right combo of resistors only or do I need a transformer? That right there is one of my biggest stumbling blocks to better luck when it comes to electronics. Who knows, maybe I someone is about to explain it in such a way that I finally get it and I will slaughter a thousand cows in that person's honor.
Changing 12V to 9V with a max output current of 0.5A is a little more complicated than using resistors. And if the voltages are DC, you can't use a transformer either!
You CAN "change" voltage with resistors (for instructional purposes, I dont like to use the word "change" since the original 12V is still there - it's the "input" and the 9V is what you want at the "output"). The circuit is called a
Voltage Divider, and you might google that term, but you don't want to use that circuit for building power supplies. A voltage divider will only give you the right voltage output if you are drawing a very small amount of current from it. As you draw more current, the voltage will change, which isn't very useful. This is the concept of Loading in electronics, and its important, especially for power supplies.
By the way, please stop me if I'm being too basic. I don't want to insult anyone but I don't want to leave out crucial fundamentals either.
You might know what series and parallel combinations of resistors are. If not,
here's a primer. So basically if you have two 10Ω resistors in series, you can just call it one 20Ω, which makes life easier. Similarly, if you have two 10Ω in parallel, you can call it a 5Ω. Three 10Ω in parallel gives 3.33Ω, and so forth.
(again, sorry for being basic but its a crucial idea to the discussion and I don't know what you know, so excuse me)
If you work out the equations of a voltage divider (which is a SERIES connection of resistors, with a point at the middle you can take your output from), you will find that the voltage at that output point is dependent on the value of the top and bottom resistors. From that wikipedia page, Vout = (R_bottom / (R_top + R_bottom) ) * Vin
You have Vin = 12 and you want Vout = 9. You can pick just about any combination of resistors that gives you the right ratio, but let's say you chose 3Ω for the top and 9Ω for the bottom. Thus, you have 12V * (9Ω / (9Ω + 3Ω)) which will give you 9V. Alright, so we have 9V, now why don't we want to use it for a power supply?
ANY circuit you hook up to this 9V will have what is called an "input impedance." (we will call it input RESISTANCE since we are only doing DC calculations). This basically means that, as far as the power supply is concerned, any circuit you hook up to it just looks like (can be modeled as) a single resistor to ground. Your multimeter won't show this if you measure the circuit by itself. The reason you can model any circuit this way, FROM THE POWER SUPPLY'S PERSPECTIVE, is that every circuit draws some amount of current when it is in use. You know Ohm's law - V = I*R. So lets say you have some big complicated circuit (perhaps an IC) that you know requires a 9V supply and draws 1A of DC current when operating. What is its "input resistance" from the power supply's perspective? Just use Ohm's law. V = IR --> R = V/I. R = 9Ω. So if you hook this IC up to your power supply, it is (almost) just like hooking a 9Ω resistor up. If your supply can't deliver 1A, you have a problem! The voltage from your supply will sag.
How does this affect the voltage divider circuit?
You have R_top as 3Ω and R_bottom as 9Ω, right? Well, lets say you want to use this 9V supply you have created to power the above circuit that draws 1A at a 9V supply. We calculated that it's input resistance is 9Ω. The circuits would look like:
Voltage Divider
The one on the left is the voltage divider circuit before attaching the load. On the right is what it looks like after. Remember that R_top is 3Ω and R_bottom is 9Ω. Well, R_load is now 9Ω. So, remembering back to Parallel resistor combinations, we can now write the parallel combination of R_bottom and R_load as one resistor... it comes out at 4.5Ω. If we re-calculate the voltage output of our divider, using the NEW R_bottom, it is:
12V * (4.5 / (4.5 + 3) ) = 7.2V
The output has sagged almost two volts. In the case of a sensitive IC, this will not suffice. Keep in mind that this is a very simplified exercise. In reality, an IC would probably start to draw less and less current as the supply voltage sagged, and you might end up with something like 8V when the two effects equalized. But 8V is still not 9V, so this exercise serves to illustrate the idea of input resistance at least in concept. This is exactly what you would see if your "complicated circuit" was simply a 9Ω resistor.
You might be thinking that you will just use smaller resistors on the voltage divider - say you used 0.3Ω and 0.9Ω. This would still give a 9V output. And if you are using the 9Ω input resistance circuit still, you can calculate what the equivalent new R_bottom would be:
using the quick formula for two resistors in parallel, R_bottom_new = (.9 * 9) / (.9 + 9) = 0.818Ω
The new R_bottom is now much closer to its original value, even after the load has been added. So the new Vout becomes:
12V * (0.818 / (0.818 + 0.3)) = 8.77V
8.77V is much closer to 9V. So this might be an acceptable solution if you reduced R_top and R_bottom even more, maybe to 0.03 and 0.09. And it would be - even for loads that require lots of current.
But, when you do this, you start to dissipate a LOT of power in the voltage divider. Even with R_bottom = 9Ω and R_top = 3Ω , the divider uses 1A just by itself (with no load). You can see this because R_top and R_bottom make a series connection for a total of 12Ω, and by ohms law, 12V / 12Ω = 1A. If you change the resistors to 0.3 and 0.9, you will draw 10A, and 0.03 and 0.09 will draw 100A! from a power perspective, this means you would be drawing 1.2W, 120W, or 1200W, continuously, all the time that your power supply is on. This isn't very efficient.
So you can see that a voltage divider will do the trick for very very low current loads, but not for much else. And they are not efficient at all. There are other circuits that will let you connect much higher current loads without needing to draw 1200W all of the time. Such circuits are known as Linear Voltage regulators. They are easy to build and you can make an adjustable voltage source out of them that is good to about 0.5A, or even more if you heatsink the chip. Chips like the LM317, LM7805, LM7812 will give you adjustable, 5V, and 12V outputs, respectively. And they are cheap and much more efficient than voltage dividers. If you want to try one they are really useful and theres thousands of tutorials online for it. Just type in "LM317 circuit" or something like that.
For more efficient DC conversion, there are also switching power supplies, but their operation is a little more complicated. They can achieve really high efficiency though. Your ATX power supply is actually a really big switching power supply (which is why they are so efficient), but they also make small chips you can buy that do switching power regulation with maybe one external inductor and capacitor - both the ATX supply and the chip operate on the same principle though.
Hopefully this helped out a little bit and gave you some examples of how to use Ohm's law and some useful insight and intuition into how circuits work. Sorry for being long winded, I consider it practice for when I start teaching this stuff. Good luck in your future circuit work, I am always happy to try and make another convert.
EDIT: accidentally put lm314 instead of the correct LM317. post has been corrected.
