Very ingenious, may I suggest you do a multiply by 5 routine (shift left twice and add to original) and call it 3 times as this will keep it in two bytes. I have a Double Dabble routine that will convert it to BCD without the need to do the final multiply by 8. I may have a go at that tomorrow if I get time. The biggest hurdle is RAM.
I had a play with your code and got rid of the sending the ROM serial twice by checking the "conversion complete" flag in the PowerBus code. I had to clear the DataBit but the result was the same length code as the send cr was two location anyway.
BTW, I'm sure you need to subtract 4 (¼°) from your extended result.
