Orcad 9.2 pcb design....
OK, i have seen that when i build project while slecting schematic led symbol come but not in pcb layout so, tell after creating schematic how to layout of it with netlist??
Man you got to be either really lazy or "mentally challenged". I don´t know why I´m still helping you when you cant even f***ing read what I posted and DO IT.
Have you tried netlisitng the goddamn schematic? What errors did you get? I got this:
#1 ERROR(ORCAP-36002): Property "PCB Footprint" missing from instance D3: SCHEMATIC1, mypcb.dsn (2.60, 3.90).
#2 ERROR(ORCAP-36002): Property "PCB Footprint" missing from instance D4: SCHEMATIC1, mypcb.dsn (3.70, 2.00).
#3 ERROR(ORCAP-36002): Property "PCB Footprint" missing from instance D5: SCHEMATIC1, mypcb.dsn (3.70, 2.90).
#4 ERROR(ORCAP-36002): Property "PCB Footprint" missing from instance D6: SCHEMATIC1, mypcb.dsn (3.70, 3.90).
#5 ERROR(ORCAP-36002): Property "PCB Footprint" missing from instance D1: SCHEMATIC1, mypcb.dsn (2.60, 2.00).
#6 ERROR(ORCAP-36002): Property "PCB Footprint" missing from instance D2: SCHEMATIC1, mypcb.dsn (2.60, 3.00).
#7 ERROR(ORCAP-36018): Aborting Netlisting... Please correct the above errors and retry.
How many times have I told you you need to assign the footprints to the parts? For example a dio400 footprint will work, but you will probably want to edit it to suit your LEDs.
  • pcb2.zip
OK, please tell me the steps to do ...I am bit confused with option coming in window i will follow it!!
for example when i open project>then i have select schematic or Pcb layout wizard???
I select schematic, never used tghe wizard. Then click add part, there is a window with libraries, so click on the button to add libraries and add them all (they are in C:\Cadence\SPB_16.5\tools\capture\library). Add a part for example an LED from the discrete library, place them and connect them. Double click on the part in the schematic, find PCB footprint column and enter for example dio400 in there.
Now click on the project page on the dsn file, then select tools-> create netlist, check create or update PCB and click ok.
It will open the new board, now select place -> manually, check the checkboxes on the parts you want to place now and put them into the board, when you´re done click ok. On the left side use the Add connect tool (F3) to make the connections between the parts. Be sure to check out the three tabs on the right of the screen, where you set layers, width etc in Option, then the Visibility, and Find which toggles which features of the part are selectable, like wires pins names etc. You should end up with about the same board like I posted before.
After this Select the product window come what to select here??
example:- Allegero PCB Design or Orcad pCb design/ stand/ prof....what to do here????
Sect any of them, I don´t think the slight differences between the different licenses matter, I usually select the first one.
OK, the board is showing in allegro design XL and if i want the layout Gerber file or in PDF how to do this i have PDF writer installed ...
and please few more thing while designing top and bottom funda...
I allways check the gerbers visually to be sure they are in the correct orientation, the names of the layers are correct and so on. Better than being sorry after you get a useless board from a fab house.
OK, I am working on schematic showing this error after design rule check...
after net list create..
Converting C:\Users\Abc\Documents\pcb\pcb.dsn to 16.3 Version Format.
Uprev Completed.
The following 1 points have been identified as net connectivity change points from the last operation
(0.70, 2.50)
(1.60, 2.50)
(3.00, 3.80)
The following 2 points have been identified as net connectivity change points from the last operation
(3.10, 3.80)
(3.00, 3.80)
(3.00, 3.50)
(3.50, 2.50)
(3.20, 3.80)
(3.30, 3.80)
(3.40, 3.80)
(3.50, 4.00)
(1.30, 2.50)
(2.20, 2.10)
(3.10, 2.10)
(4.10, 2.10)
(5.20, 2.10)
(6.20, 2.10)
(7.20, 2.10)
(2.80, 5.20)
(8.50, 2.80)
*  Design Rules Check
Checking Schematic: SCHEMATIC1
Checking Electrical Rules
WARNING(ORCAP-1831): Unconnected pin U1,CLK
WARNING(ORCAP-1831): Unconnected pin U1,C\L\R\
WARNING(ORCAP-1608): Net has no driving source N00658
Checking For Single Node Nets
WARNING(ORCAP-1600): Net has fewer than two connections GND
WARNING(ORCAP-1600): Net has fewer than two connections VCC
Checking For Unconnected Bus Nets
(2.80, 5.20)
(2.80, 5.20)
(3.10, 5.20)
INFO(ORCAP-32002): Netlisting the design
INFO(ORCAP-32004): Design Name:
Netlist Directory:
C:\Users\Abc\Documents\pcb\allegro
Configuration File:
C:\Cadence\SPB_16.5\tools\capture\allegro.cfg
Spawning... "C:\Cadence\SPB_16.5\tools\capture\pstswp.exe" -pst -d "C:\Users\Abc\Documents\pcb\pcb.dsn" -n "C:\Users\Abc\Documents\pcb\allegro" -c "C:\Cadence\SPB_16.5\tools\capture\allegro.cfg" -v 3   -l 31 -s "" -j "PCB Footprint" -hpath "HPathForCollision"
#1 ERROR(ORCAP-36002): Property "PCB Footprint" missing from instance D3: SCHEMATIC1, PAGE1 (4.70, 2.40).
#2 ERROR(ORCAP-36002): Property "PCB Footprint" missing from instance D4: SCHEMATIC1, PAGE1 (5.70, 2.40).
#3 ERROR(ORCAP-36002): Property "PCB Footprint" missing from instance D5: SCHEMATIC1, PAGE1 (6.70, 2.40).
#4 ERROR(ORCAP-36002): Property "PCB Footprint" missing from instance D6: SCHEMATIC1, PAGE1 (1.70, 2.40).
#5 ERROR(ORCAP-36002): Property "PCB Footprint" missing from instance D7: SCHEMATIC1, PAGE1 (7.70, 2.40).
#6 ERROR(ORCAP-36002): Property "PCB Footprint" missing from instance D8: SCHEMATIC1, PAGE1 (0.80, 2.40).
#7 ERROR(ORCAP-36002): Property "PCB Footprint" missing from instance U1: SCHEMATIC1, PAGE1 (2.70, 4.30).
#8 ERROR(ORCAP-36002): Property "PCB Footprint" missing from instance D1: SCHEMATIC1, PAGE1 (2.60, 2.40).
#9 ERROR(ORCAP-36002): Property "PCB Footprint" missing from instance D2: SCHEMATIC1, PAGE1 (3.60, 2.40).
#10 ERROR(ORCAP-36018): Aborting Netlisting... Please correct
Exiting... "C:\Cadence\SPB_16.5\tools\capture\pstswp.exe" -pst -d "C:\Users\Abc\Documents\pcb\pcb.dsn" -n "C:\Users\Abc\Documents\pcb\allegro" -c "C:\Cadence\SPB_16.5\tools\capture\allegro.cfg" -v 3   -l 31 -s "" -j "PCB Footprint" -hpath "HPathForCollision"
INFO(ORCAP-32005): *** Done ***
  • Desktop.rar
Ok, so as for the warnings:
wasn´t connected to anything beacuse the VCC wasn´t at the right spot, use R to rotate parts and check they are connected properly
These are for U1, double click it and check the box Power pins visible, then connect to vcc and gnd manually - it is safer than relying on the automatic power connections.
As for the errors, this has to be at least sixth time when you HAVE NOT SET THE ******* FOOTPRINT! Doble click each part and writhe the footprint in to the Pcb footprint property. All parts must have it.
Is anybody else watching this thread? Are you having as much fun as I do? [smiley-vomit.gif]
Now i have connected the footprint to led as you said in preevious post and U1 to supply maualy i have no idea of 74164 footprint lib what to write??
here are the error...
Uprev Completed.
(0.70, 2.50)
(1.60, 2.50)
(3.00, 3.80)
(3.10, 3.80)
(3.00, 3.80)
(3.00, 3.50)
(3.50, 2.50)
(3.20, 3.80)
(3.30, 3.80)
(3.40, 3.80)
(3.50, 4.00)
(1.30, 2.50)
(2.20, 2.10)
(3.10, 2.10)
(4.10, 2.10)
(5.20, 2.10)
(6.20, 2.10)
(7.20, 2.10)
(2.80, 5.20)
(8.50, 2.80)
(2.80, 5.20)
(2.80, 5.20)
(3.10, 5.20)
Netlist Directory:
Configuration File:
(3.30, 5.20)
(3.30, 5.20)
(3.10, 5.20)
The following 3 points have been identified as net connectivity change points from the last operation
(2.80, 5.20)
(3.30, 5.20)
(3.10, 5.20)
(4.80, 5.20)
(4.80, 5.20)
(3.30, 5.80)
(1.90, 5.10)
(4.80, 5.20)
(3.30, 5.80)
Netlist Directory:
Configuration File:
#1 ERROR(ORCAP-36002): Property "PCB Footprint" missing from instance U1: SCHEMATIC1, PAGE1 (2.70, 4.30).
#2 ERROR(ORCAP-36018): Aborting Netlisting... Please correct the above errors and retry.
Well, it is a 14 pin DIP package, so look into c:\Cadence\SPB_16.5\share\pcb\pcb_lib\symbols\ directory and take a guess. I can't keep telling you which package to use for what.
OK, I am using this dip14_3 and after creating net list allegro PCB design has opened showing nothing asking this
Opening existing design...
Command >
(7.20, 2.10)
(2.80, 5.20)
(8.50, 2.80)
(2.80, 5.20)
(2.80, 5.20)
(3.10, 5.20)
Netlist Directory:
Configuration File:
(3.30, 5.20)
(3.30, 5.20)
(3.10, 5.20)
(2.80, 5.20)
(3.30, 5.20)
(3.10, 5.20)
(4.80, 5.20)
(4.80, 5.20)
(3.30, 5.80)
(1.90, 5.10)
(4.80, 5.20)
(3.30, 5.80)
Netlist Directory:
Configuration File:
Netlist Directory:
Configuration File:
Scanning netlist files ...
Loading... C:\Users\Abc\Documents\pcb\allegro/pstchip.dat
Loading... C:\Users\Abc\Documents\pcb\allegro/pstxprt.dat
Loading... C:\Users\Abc\Documents\pcb\allegro/pstxnet.dat
packaging the design view...
* Updating Allegro PCB Editor Board
INFO(ORCAP-32040): Updating Allegro PCB Editor Board
Spawning... netrev.exe -5 	-y 1 -n   -i "C:\Users\Abc\Documents\pcb\allegro" "C:\Users\Abc\Documents\pcb\allegro\pcb.brd" "C:\Users\Abc\Documents\pcb\allegro\pcb.brd"
Reading File : C:/Users/Abc/Documents/pcb/allegro/pstchip.dat
(00:00:00.07)
Reading File : C:/Users/Abc/Documents/pcb/allegro/pstxprt.dat
(00:00:00.01)
Reading File : C:/Users/Abc/Documents/pcb/allegro/pstxnet.dat
(00:00:00.00)
Starting to process component instances
   Finished component instance processing
Starting to check device models
   Finished checking device models
Starting to process nets
   Finished net processing
Starting to process slot properties
   Finished slot property processing
Starting to process component instance properties
   Finished component instance property processing
Performing a partial database check before saving.
Writing database to disk.
'pcb.brd' saved to disk.
netrev run on Apr 7 20:21:06 2013
   DESIGN NAME : 'PCB'
   PACKAGING ON Apr 21 2011 10:02:30
 No error detected
 No oversight detected
 No warning detected
cpu time      0:01:16
elapsed time  0:00:00
Exiting... netrev.exe -5 	-y 1 -n   -i "C:\Users\Abc\Documents\pcb\allegro" "C:\Users\Abc\Documents\pcb\allegro\pcb.brd" "C:\Users\Abc\Documents\pcb\allegro\pcb.brd"
(    Allegro Netrev Import Logic                                      )
(    Drawing          : pcb.brd                                       )
(    Software Version : 16.5P002                                      )
(    Date/Time        : Sun Apr 07 20:21:06 2013                      )
------ Directives ------
RIPUP_ETCH FALSE;
RIPUP_DELETE_FIRST_SEGMENT FALSE;
RIPUP_RETAIN_BONDWIRE FALSE;
RIPUP_SYMBOLS ALWAYS;
Missing symbol has error FALSE;
SCHEMATIC_DIRECTORY 'C:\Users\Abc\Documents\pcb\allegro';
BOARD_DIRECTORY '';
OLD_BOARD_NAME 'pcb.brd';
NEW_BOARD_NAME 'pcb.brd';
CmdLine: netrev.exe -5 -y 1 -n -i C:\Users\Abc\Documents\pcb\allegro C:\Users\Abc\Documents\pcb\allegro\pcb.brd C:\Users\Abc\Documents\pcb\allegro\pcb.brd
------ Preparing to read pst files ------
Starting to read C:/Users/Abc/Documents/pcb/allegro/pstchip.dat
   Finished reading C:/Users/Abc/Documents/pcb/allegro/pstchip.dat (00:00:00.07)
Starting to read C:/Users/Abc/Documents/pcb/allegro/pstxprt.dat
   Finished reading C:/Users/Abc/Documents/pcb/allegro/pstxprt.dat (00:00:00.01)
Starting to read C:/Users/Abc/Documents/pcb/allegro/pstxnet.dat
   Finished reading C:/Users/Abc/Documents/pcb/allegro/pstxnet.dat (00:00:00.00)
------ Oversights/Warnings/Errors ------
------ Library Paths ------
MODULEPATH =  .
           C:/Cadence/SPB_16.5/share/local/pcb/modules
PSMPATH =  .
           symbols
           ../symbols
           C:/Cadence/SPB_16.5/share/local/pcb/symbols
           C:/Cadence/SPB_16.5/share/pcb/pcb_lib/symbols
           C:/Cadence/SPB_16.5/share/pcb/allegrolib/symbols
PADPATH =  .
           symbols
           ../symbols
           C:/Cadence/SPB_16.5/share/local/pcb/padstacks
------ Summary Statistics ------
   DESIGN NAME : 'PCB'
   COMPILE 'logic'
   CHECK_PIN_NAMES OFF
   CROSS_REFERENCE OFF
   FEEDBACK OFF
   INCREMENTAL OFF
   INTERFACE_TYPE PHYSICAL
   MAX_ERRORS 500
   MERGE_MINIMUM 5
   NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
   NET_NAME_LENGTH 24
   OVERSIGHTS ON
   REPLACE_CHECK OFF
   SINGLE_NODE_NETS ON
   SPLIT_MINIMUM 0
   SUPPRESS   20
   WARNINGS ON
 No error detected
 No warning detected
cpu time      0:01:16
... It will open the new board, now select place -> manually, check the checkboxes on the parts you want to place now and put them into the board, when you´re done click ok. On the left side use the Add connect tool (F3) to make the connections between the parts. Be sure to check out the three tabs on the right of the screen, where you set layers, width etc in Option, then the Visibility, and Find which toggles which features of the part are selectable, like wires pins names etc. You should end up with about the same board like I posted before.
Do you even read what I write?
It will open the new board, now select place -> manually, check the check boxes on the parts you want to place now and put them into the board, when you´re done click ok.
I have done this no component seen on screen...,why??
so, how to do this?
When you click the place -> manually, do you see the components in there? Maybe try reading that sentence again and doing EXACTLY as I said. You need to check the checkboxes, place the components and THEN click ok.
