I have some home work to study and wondering if anyone can helps , My objective is to name all these components from a laptop motherboard and test them with a multimeter ,
I will go thought what I have done to test and if I am wrong in anything then please tell me.
From my picture number 1 . power choke coil or inductor / continuity test - Beeps / Resistance 0.3 . I think the test says its good and it should beep , not sure about resistance value I think zero is bad
2. Diode / Continuity - No beeps / Diode on multimeter .0L . I think this is bad because of the .0L reading
3.. Capacitor , No Beeps / resistance mode . 4.000 Ohm starts of and move up in value , I think this capacitor is ok but I am not sure . mesr meter reads 0.010 which is low and the capacitors don't have the values on them to work out, so I am some what confused and the readings on these small caps.
4. Capacitor No beeps / . resistance 0.700 ohm and moves up , mesr 0.010 . not sure these readings are good or bad they seem quit low .
Any help with this will be very appreciated .
https://imgur.com/SXY69rq![](https://i.imgur.com/SXY69rq.jpg?1)
