PCB Help?
oznovice
Hi experts
I'm a novice with electronics and was hoping someone here at an idea of how to fix this issue I am having with a 24V (battery powered - solar charged) gate motor control board. It seems to work more at night (so no power charging the batteries) and randomly during the day, unless it's hot/humid, then it just doesn't work.
I will post a pic of the unit and the board diagram from the manual if that helps.
The model is:
ISC800DC Sliding Gate Opener
So I have troubleshooted the following
Confirmed 26V volts at the board from the batteries.
Confirmed the remote is working, by manually checking Relay 1 (opening the gate) works. I originally thought it was the relay not working, so I opened the top of Relay 1 (see pic) and manually actuated it while pressing the remote and the gate ran the Open Cycle. Without manually moving the contacts on the Relay, it doesn't run power to the motor. When the unit started playing up originally, a flick with the finger (tap) on the pcb outer cover while pressing the remote would get the gate to open.
Confirmed no power (obviously) on the PCB to the motor connector when the unit is playing up.
When the unit is playing up and not working with the remote, I have noticed this module (I believe it's a Voltage Limiter??) gets hot. I dont have an accurate temp on it, but it's almost too hot to touch.
I have installed switches to turn off solar charge to the batteries (so no power to the PWM controller from the solar panels but pwm still connected to batteries, so power available at the Load output of the PWM), and I have a switch to turn off power to the Control Board (which then allows that Module (voltage limiter) to cool down). Turning the power off to the PCB for a while, used to correct the problem until that unit heated up again. The manual shows the Load output of the PWM connects to the PCB of the gate motor.
I have checked the rear of the PCB and see no burn outs and have resoldered/cleaned the solder points on the pcb that looked dull.
If it's a simple fix, I would just rather replace a module on the PCB rather than buying an entirely new 24V electric gate, as it seems buying another complete kit is about the same price as a new control board and a lot of work to replace the entire unit. It's about 7 years old.
I think it's not getting the signal to engage the relays to run power to the motor somewhere, but as mentioned, manually actuating a relay while pressing the remote does send power to the motor, so I think the remote sensor on the pcb is working correctly. So whatever is supposed to actuate the relays (open and close) I think could be causing the issue. Could it be an internal failsafe on the PCB, for heat/outside temp/humidity? This model gate opener uses Magnets to determine if the gate is open or closed. All LEDS are lit when the unit is fully opened or closed, so I thought that meant the PCB was reading the gate position correctly?
Is that small blue box a relay as well? (see pic).
I'm totally stumped. I have to replace relay 1 as I have opened the top, and was thinking of replacing the other, plus the Blue Box one (if that's a relay also). It just doesnt make a lot of sense to me that it works fine for a few days and nights, then wont work sometimes, even at night.
Any help you experts could offer would be much appreciated.
edit: forgot to mention, I tried installing an adjustable voltage regulator with digital display which seemed sort the problem (being able to limit volts and amps to the PCB), however, the regulator has a input limit of 31 volts and the 24V solar array in full sun, puts out about 31.5v, which obviously the PWM controller limits the charge to under that for the 24v batteries. When more than 31 volts, the regulator trips it's over voltage input protection and stops working.
The "Working when its tapped" fault indicates its most likely either a bad relay contact or a dry / cracked joint on a component.
Or possibly a loose pin in one of the connectors?
Hi thanks for the reply. I have removed all the connector wires and tested. All connections seem fine. Last night when I put the PCB back on and reconnected the wires, the gate worked. This morning when charging with the solar in full sun 30c and 78% humidity, it didn't work until I manually engage the contact on the Relay 1 (motor open) while pressing the remote. Tapping doesn't seem to work anymore. I thought a relay engaged when power is sent to it, or is power always at the relay and there's a switch on the pcb to engage it? The motor ran fine once manually accuated, and seemed like it was getting sufficient power as it wasn't slow. Does this type of relay always have power, and another switch engages it? or could the PCB is getting too many volts/amps from the battery/solar controller and the control board is not letting motor run as like a fail safe? I dont understand either why the Solar Controller would put 31.4 volts into the 2 AGM batteries every now and again when it's float charge is set to 27.6 I have used a lot of 12v solar arrays, and if charging a 12V system, 15.7 volts seems high to put into a 12v agm battery. Oh, and I have replaced the solar controller with another, and it seemed to do the same (battery type b01 24v). Batteries when not on charge sit at about 25.8 after a day or so of not being charged. If a battery, or both are on the way out, could the solar controller be trying to dump a quick higher charge into them, like a smart charger might do? As the volts at the battery input on the pcb match whatever the solar panels are putting out (2 x 20W solar panels), I wasn't sure if that was the cause of the hot integrated volt regulator on the pcb.
The battery voltage should be around 13.8V each for float charge, or ~14.8V for cyclic charge discharge. If they stay fully charge most of the time, set it at 13.8V
Anything more than 15V will drastically shorten the battery life; they only last around 3 - 5 years if on float at the correct voltage, much less if overcharged as it dries them out.
They could already be drying out and high resistance?
From what you are saying, it may be getting insufficient voltage to the relay, so it's almost pulling in and an tapping or pressing it allows it to fully pull in and the contact connect.
The relay itself will only be powered when it should be activated; there will be an external (transistor) switch controlling power to it.
On the PCB it designates J4?? but you have a TO220 transistor in there? Is there a PCB track view?
Hi Ian, I have no idea what a J4 is, or TO220. Track view? Do you mean rear of the PCB? I can take the pcb off tomorrow and put up a photo. This model pcb I can't even locate to buy a new one.
Hi rjenkinsgb, I was thinking of replacing the batteries. I have a good analyzer and will check them tomorrow, but they are at least 7 years old (not sure how old they were when I bought the kit from the supplier). I will order 2 new AGMs as I am concerned with the 31.5+ volts being sent to the 2 batteries. 14.8 volts like you said for 1 battery would be 29.6 volts for the 2. Thanks for confirming 15v for 1 battery (30v for 2) is too high. I will also replace the Solar Controller with a better one as well. The strange thing is, when it's night and not on charge, the gate motor runs properly (close and open), but then that little module gets hot, and it doesnt work again until I shut off power from the batteries to the pcb for a while. I managed repeat the 'tapping' on different modules last night and it would work only 2 cycles until I let that module cool down. I hear the relay click when pressing the remote as well, but which relay, I am not sure. So can you tell me where the relays get their power from? Is it the Blue box (relay/switch)? I really appreciate the help you all are offering as there's no electronics tech in my area to take it to, and I dont have a bench test setup. Is there a way to test with a voltmeter how many volts are running to the relays? I have checked the Battery connector pins on the pcb and it matches the battery (which can spike to 31.5+ volts every few minutes)
I would suspect that one of the relays is not disconnecting when it should, and causing extra current to be taken, which makes the T0220 component get too hot.
A thread on here a week or so ago had a cooker control board where the relay failed.
My Apologies.... J4 is the MOT connector it looked like the three pin jumper. this is a T0220
case style although UV4 means nothing to me.
look at those pictures "This gets hot" between the cap and the MOT connector looks like the
jumper is J4 .. although the picture on the right is upside down it's clearly a transistor.
if it is the Motor driver it may need a heatsink as it will get hot.. We could really do with a schematic ( or a picture of the PCB tracks..
Thanks Diver300. Reading the replies, I accept that's probably the issue. I just wasn't sure what RL6 was for (blue). I will put the rear photo of the pcb up tomorrow. I just noticed on the board drawing, Transformer in AC24v. I thought it was DC24V. So this unit has an inverter to go to from DC to 220v/110v? That large coil on the rear of the pcb mounting plate is not what I have seen on other DC Solar Gate kits. I will look up that cooker control board post, thanks for that.
The motor will be 24V DC; no inverter.
The thing on the back of the plate in that photo is a toroidal transformer, presumably to reduce the mains input to 24V AC.
Thanks rjenkinsgb that makes sense now, as the double blue wires connected to the pcb go back to that transformer and explains why the gate still worked with those wires disconnected. Edit: So, I have compared this latest image with the one I put earlier, and it appears this module (circled) now has a grey section. Does anyone know what this module is and is it related to the relays? I think its D15 on the board drawing from the manual. If it's a diode, how do I find out the specs to replace it?
It's a diode, almost certainly connected in parallel with the relay coils to reduce the voltage spikes that the transistor driving it is subjected to.
https://en.wikipedia.org/wiki/Flyback_diode if you want to know more.
Also likely that it's fine. They very rarely fail. The colouration of the ends is just how the light is reflecting from the surface of the plastic moulding.
In the unlikely event that it has failed, almost any diode rated at 1 A or more would be fine.
The item circled is a diode. I don't know if it is related to the relays.
My approach to tracing the fault would be to wire an LED (With a series resistor (About 2.7K) and the correct LED polarity.) in parallel with the coil of each of the black relays to see if the coil is being energised. (The left hand picture in post #1 showes the coil connections.) I think one of these relays is for forward and the other for reverse. When the gate is in a working state verify that one LED lights for the forward direction and the other for reverse. If the LEDs behave in the same way when it is in a not working state then the fault is one of the black relays. If they do not light as in the working state then the fault is in the drive circuit.
Have you tested the limit switches are working at the connector J10 ?
Les.
