Both vertically and horizontally ?
with the red arrow I get 1" where it says not here I don't which is the original pinhead. As you can see I joined it together I don't know if I was supose to do that.
It is OK to join them as if you understand that the vertical one gains .1 inch if you count the horizontal one it is butted up against.with the red arrow I get 1" where it says not here I don't which is the original pinhead. As you can see I joined it together I don't know if I was supose to do that.
HAHAYou are difficult to get information out of ! ,
I have a Brother MFC-440CN and yes I am using Eagle's print dialog.What printer do you have and are you printing from Eagles print dialog ?,
Wow you caught that ! I removed it shortly after I posted it.
In the eagle print dialog there under Calibrate
change the X and Y settings from 1 to about 1.1 and try printing again
with the right setting you should get the right size.
Are you going to etch the PCB yourself.
