Phillips tv dead
bigduke
Hello all,
I have a Phillips PW6506 with a dead screen and no sound.
The fault originated with rapid clicking when first powered up and then would take about ten on and off with the power to gain a steady picture. Yesterday I suddenly lost the picture and the small power light no longer illuminates. I know that I shouldn't have let the go this far but this is where I'm at. I don't suppose that the clicking was due to a contactor which now has burned off contacts? Or could it be a capacitor fault as I would have to wait until the small red light light went out before switching on again. Also the picture would take a few minutes to stabalize on the right hand side of the screen.
Hope that someone can help.
Cheers BD
It could be a line output transformer fault - I think the ticking noise is a symptom.
If you are lucky, then it may be just a dry joint on one of it's pcb pins.
If it has blown, it is an expensive repair and they can also cause the driver power transistor and other parts to blow.
WARNING!! A TV HAS DANGEROUS VOLTAGES PRESENT EVEN SOME TIME AFTER POWER OFF!
DO NOT ATTEMPT ANY REPAIR UNLESS YOU ARE FULLY EXPERIENCED IN WORKING WITH HAZARDOUS VOLTAGES!
(I would now consider just getting a new LCD tv if any old tube type one fails rather than trying to repair it)
A VERY common fault on them is a small blue disc capacitor in the line output stage, these usually go S/C with obvious burn marks on them, and often a 'death smell' - I did one last night.
The capacitor is the tuning for the line output stage, so it's essential you replace with the correct value - the one I did was 1500pF 2KV.
BTW, in the set I did the capacitor was C2420.
Nigel Sir,
I have a Phil;ips model 21PT2125/94/c (Indian made).
More frequenctly it currupts the contents of EEprom . I had got it serviced by paying for a chip replacement. Still things repeat. At the time of failure, the set shows an extra display Stereo on top left. The picture starts binking at 1 sec interval, and audio fails.
I feel it might be due to power flicks, and an analysis indicated that the EEPROM pins are not protected by 5V zenors on the address and SCL and SDA pins.
should i venture to mount them.?
He called you Sir, twice! Have you been knighted by the Queen herself and not informed any of us here about that dubious title?:rolleyes:
I beleive i said Nigel Sir , but not Sir Nigel
It is out of respect, and if it is uncomfortable to the British way of life , I beg pardon.
mvs sarma said:
I beleive i said Nigel Sir , but not Sir Ngel
It is out of respect, and if it is uncomfortable to the British way of life , i beg pardon.
It's not something that is done in English, but as you have your location filled in I knew English wasn't likely to be your first language. Unlike the uncouth Americans :D I wouldn't criticise someone for being excessively polite and respectful, particularly when it's a feature of their culture.
Thanks for the replies.
There is a steady bird like chirping sound from the line output transformer.
Cheers
It's tripping - the disk capacitor causes this, as would the line output transistor being S/C (and other things) - but check the capacitor, the odds are it's that!.
