Photoresistor
jabal29
..I bought solar bulbs from Ali Express and I want automatic turn on and off according to ambient light..So I bought photo resistors to hook on the bulb system..There is a switch on the bulb to turn the light on with several sequences of lighting..How should I bypass that switch so to have the photo resistor control the light on and off..?
You bought the wrong light bulbs. To modify a device, you must learn exactly how was it designed. Do you have a schematic ? Are you aware if there is a microcontroller with firmware/program in it ?
I don't know too much about electronics.. however I think it should not be very difficult to get the photoresistor operating..I thought you could tell me if I should plug it on the battery+ or -..or on the LEDs..
You think wrongly - a photo-resistor isn't a switch, you would need to add a fair few more components (such as a comparator and associated components) to make it operate as one.
Some circuits here to detect and switch on LEDs, attached
Regards, Dana.
  • 110814953-555-Timer-and-Its-Applications.pdf
  • Forrest Mims-engineer's mini-notebook 555 timer circuits (radio shack electronics).pdf
  • Il timer 555.pdf
True, it changes resistance when exposed to light. To get it working you probably need a transistor and some other components like in this schematic.
Athosworld , where did you find that terrible circuit?
I'm not sure Q1 will ever turn off with its base connected to 9v. And, why would you do high-side switching with an NPN transistor?
True, it changes resistance when exposed to light. To get it working you probably need a transistor and some other components like in this schematic.View attachment 143163
Worst possible 'circuit' in the world, and then it's even drawn completely wrong with parts missing :D
And where do you found a 100 ohm LDR?.
Years ago, solar garden lights used photo-resistors that got sunburned and failed. New solar garden lights use the glass-covered solar panel to detect light and turn the LED on and off.
