The RA0 pin is rugged, the PIC comparators are rugged and proven, the most likely thing is a PIC latchup reset issue. Possibly with a CONFIG issue that has programmed the PIC with _MCLR_ON (which explains the PIC reset issue) and LVP_ON, (which explains the unable to program issue).
Like I said my meter gets used all the time and I don't baby it, it has had caps connected that have been pulled from the breadboard and may have been charged to 12v or so, and the cap meter has not played up in any way not even as much as a single latch-up. Please check your programmer and CONFIG settings.![]()
If something is killing your PIC so it cannot be programmed you must be doing something seriously wrong!
This is your file and programming the pic and reading it back shows 0x3F02
Thank you for being so patient. I think now what it was, was the coaxial power connector was making an intermittent contact and as I connected the cap the unit moved causing the problem.
When the unit is fastened down and the connector is fully seated I can not duplicate the crash.
Fortunately the pic's are only two dollars apiece, if you buy 10, so not a major cost item.
Exactly my thoughts, I have a so-so cap meter on my multimeter so I don´t need another one, but with an ESR meter added it would be a great troubleshooting tool and I´m building it ASAPHi RB, personaly i think a ESR meter add on would make it a must have no question about it kinda thingyeah i would be very very keen to build one
