You wanted to use your PC as "the display" for capacitor measuring?
I thought you were the resident expert here on using lots of cool LCDs etc?
To me the cool part of the project is that it's a little handheld cap meter that I can grab and carry off to test caps on the workbench or going through a junkbox or testing the capacitance of something in the field (even a cable etc).
Hi Mr.RB and All.
I build the high res cap meter in breadboard. It worked fine but cap values are 15-30% hi. I build it again on Melab prototype pcb which is much professional finish. The same things happen cap meter read 15% for small cap and 20%-30% for larger cap. ( 22pf reads 28pf 1u reads 1.2u). 10 k resistor is chosen to be 10.01K as read by DVM.Can some body please suggest a solution?. Capacitors measured are 5%.
Obaid
