It's just a JDM programmer with a FT232 and ZIF socket.
That's just the thing. JDM's very often just plain don't work. We get messages in this forum constantly from people who can't get JDM programmers to work. They were designed long ago for old fashioned computers. Computers have changed. JDM's sometimes work, but very often not on modern computers.
And we're giving you excellent advice for the best way to get started. A few cables, connectors, crystals/caps are very very cheap. The crystal & caps are not really necessary on most PICs, as they mostly have internal oscillators. PICs are cheap too.
That 16F84A is an antique. Better to start with a more modern chip.
Buy a JDM if you want, but don't be surprised if it won't work and you end up scrapping it and buying something better anyway. You won't get your money back from an Ebay seller.
For an experimenter, programming PICs in a ZIF or standard IC socket like this thing sucks! It's a horrible way to work. You program your chip, pry it out and plug it into your target circuit, find out it doesn't work, pry it out, plug it into the programmer, make your change, pry it out and plug it into your target circuit, find out it doesn't work, pry it out, plug it into the programmer, make your change, pry it out and plug it into your target circuit, find out it doesn't work, pry it out, plug it into the programmer, make your change, pry it out and plug it into your target circuit, find out it doesn't work, pry it out, plug it into the programmer, make your change... Hundreds and thousands of times! It's slow and tedious. The pins on the chip wear out and break off.
With ICSP you have a simple 5-pin connector on your target circuit with a cable to the programmer. When your program doesn't work, you make your change and hit a couple keys or mouse clicks to reprogram the chip and test again. Simple and quick.
And another huge badness with the JDM - no debugging. Hardware debugging is something that, once you've tried it, you wonder how you ever got along without it. PICkit 2 and ICD2 programmers do debugging, working with the MPLAB IDE software to make finding out what went wrong with your code vastly easier than doing it without a debugger.
Of course david you are saying that "this one is fine" when you have zero experience, and as apposed of listening to experienced members you rather waste money. Getting a PICkit2 or Junebug makes more sense.
And ICSP.
Probably best to go with the PICkit2 clone though since it's compatible with Microchip's software.
i did not say that i sayed ( i think or i ment) it looks fine i just did not know that it being suckish that it flat out does not work. ok brah'.
I'd stay far, far away from that thing. It's a copy of a DIY K150 programmer, which is almost totally unsupported these days. I own one. It sits in the junk box now. Useless!ok i got it. so this one
is usb, has a zif socket, has an ICSP cable, and is not JDM. and i could go and get a few PICs from jameco. so I think I will get this one. one more question.
what programs will i use to write the .hex (or linux equivalent) and one to program the pic
MPLAB won't work for me with Wine. But there is a pretty good alpha-stage program called Piklab that works reasonably well. No debugging for PICkit 2's yet though.yeah but will the microchip software be available for linux
I'd stay far, far away from that thing. It's a copy of a DIY K150 programmer, which is almost totally unsupported these days. I own one. It sits in the junk box these days. Useless!
It was great when it was new in 2002 or 2003, but the company no longer wants to support it, so no more updates. It won't program many PICs, especially the newer models. And it won't do debugging. Period.
For the same money you can get a modern PICkit 2 or clone. Awesome support, from the company that makes the chips! Debugging. What's not to like?
MPLAB won't work for me with Wine. But there is a pretty good alpha-stage program called Piklab that works reasonably well. No debugging for PICkit 2's yet though.And BoostC works perfect with Wine!
Eventually it'll be a nice program. Already it's amazing considering how young the project is. Right now it's useable, but doesn't really hold up in comparison to MPLAB. I'm a Linux guy, but I keep one Windoze box for microcontroller programming because the best tools are all Windows. Sad but true.
There it is! I was looking for that one. Comes with your ICSP cables too. Price is a tad high, but ok.alright looks like im getting a pickit2
this one
and i will get a few pics
I have one Mint box, but I'm almost totally an Ubuntu guy these days (they're the same thing anyway). Once I finish tuning Mint to suit myself it looks/acts exactly like my Ubuntu box anyway, so why bother? Same goes for pretty much every distro I use though. So lately I just don't try the other ones and stick to the one I know - Ubuntu.what distro are you running. i have linux mint on my ibm t41 i had ubuntu but im really feeling linux mint.
Hex is hex. Doesn't matter whether you work in windoze, linux or mac. The standard output file for PICs is good old Intel hex.one more question.
Oops! Ya, gigahertz. 1700MHz, that is.Megahertz? Do you mean Gigahertz?
i dont see a pin out or the names of the pins of the ICSP cable on the pickit2. what are some recommended pics for beginners. i would like some of all sizes
Pin 1 - VPP - To the MCLR pin on the chip. Don't forget to put a 33K or so pullup resistor on MCLR too (not critical - anything from 4.7K to 33K is ok).
Pin 2 - 5V - To VDD on your target circuit.
Pin 3 - Ground - To Ground on your target circuit
Pin 4 - PGD - To the PGD pin on the PIC
Pin 5 - PGC - To the PGC pin on the PIC
Get a 12F683, 16F88, 18F1320, 18F2550, 18F4550 or 4620. That gives you a bit of a range of different chips in different sizes with different peripherals. Other people will suggest some others probably. Whatever. Once you learn one, the rest are very similar. The PIC product line is very standardized. They mostly just have more or fewer onboard peripheral modules.
Get a 4MHz and a 20MHz crystal and a few 22pF ceramic disc capacitors. Get a dozen or so 0.1uF ceramic caps and the same number of 100uF electrolytics (and maybe a few 10uF). Some 33K (dozen), 10K (dozen), 4.7K (dozen), 1.2K (dozen), 1K (25), 330 (50) and 180 (25) ohm resistors is good to start with. If you buy these in 200-quantity or better you'll get a big price break. Get some 5mm LEDs - red, green, yellow, blue, whatever you want. A couple 10K trimpots with leads suitable for plugging into a breadboard. Some pin header. Some IDC connectors and an old 40-conductor IDE cable or a floppy cable to rip up and make programming cables out of. Some 2-row header pins and some IDC male headers to make breadboard ICSP adapters out of. A **broken link removed** or two (or more) and **broken link removed** (or make your own). A roll of 30ga wire-wrap wire is useful for projects, but get a roll of something more like 26ga or 24ga for breadboard wires (30ga is too thin). A decent soldering iron and some small-guage rosin-core solder and a can of rosin paste flux too. That's a good start. What have I forgotten? Probably a few things...
