I need to build a pick and place device using two pneumatic cylinders, one for the horisontal and one for the vertical movement. Vacuum will be used to pick up the plastic parts; typically 7.0 mm diameter x 1.6 mm thick. I also want to use normal limit switches at the end of each stroke, not magnetic reed switches.
Can some one help me with the design of a basic circuit please?
The device will be used as a good visual display of electrical and pneumatic utilisation.
Thanks,
Dave Pretorius.
Thanks,
Dave Pretorius.
