Abdullah2121
please I want to construct transducer with 5 MHz , please help me
Abdullah2121 said:please I want to construct transducer with 5 MHz , please help me
Abdullah2121 said:thanx , but the problem that i'm in jordan and there's no transducer higher than 40 khz , and i want to change it to 5 mhz if there's solution please tell me , and i also i want to know how i can construct the circuit that transmuter 5 Mhz signal ....
hi,Abdullah2121 said:I want my range 1 meter , and i want it from transmitter to receiver ...
3v0 said:google radar ultrasound
Abdullah2121 said:my graduation project is circuit that act like radar to determine the directions, the idea was taken from the bat that can determine its direction by using the ultrasound, I have transducer 40khz but i have idea to change it to 5 mhz by decreasing its thickness , because the transducer frequncy depends on the thickness, the summary i want transmitter send signal and if there's any reflection signal received by receiver , and the distance around 1 meter.
Abdullah2121 said:sorry i mean glass paper .... I can do it
Abdullah2121 said:sorry man to confuse you , but really i want the answer ......![]()
blueroomelectronics said:It would appear the OP hasn't done their homework.
