Hey there
I need a small circuit for a momentary button I have in my car.
the idea is I have one wire I need to cut to turn off something then I need to turn it on again but the problem that the switch that I have to use as I said is momentary and I need it to work as a normal ON\OFF switch with out doing any thing to the momentary button
so when you push momentary button the circuit cut off the power from this wire and if you push momentary button again it well connect
thanks
thanks
