I'm using basic op amp comparator to switch on a LED when battery voltage falls below a set point (11.8 V) and switch it off when battery rises to 13.8 v (so I've got some positive feedback hysteresis from pins 3 to 6). The problem is that the 5V6 Zener I'm using as a V reference at the input is taking nearly all of the circuit current! I have to use a lowish K resistor to bias the zener (it needs about 10mA to work correctly) but this is using more mA than I want. Has anyone got another lower current option? TL431....? NPN transistor...? Is there a very low current zener available?
I only want to use a simple 741..TL082....etc. op amp circuit, but with a stable low current (uA) reference. The battery voltage is not regulated, and falls with use, so can't be used as a stable reference.
