There is absolutely no reason to buy a Jacob's Ladder kit, especially not for $56.99! Jacob's Ladders are one of the easiest projects to make and you can generally make it at very little cost, if not free.
True, though I never bothered with the tube. Stiff enough wire (coathanger wire, for example) is usually strong enough to hold itself up, and even if it couldn't I could always put some sort of non-conductive (often plastic or dry wood) cap at the top to hold the wires the correct distance apart.I agree, usually the most expensive thing is the tube to surround the electrodes. Fist one I made with a tube the tube was some type of plastic, didn't last long. Think it was the ozone that made the plastic go bad. A better one was made from glass tubing that was for a milking system, but expensive at the time. Don't know the cost today though. The surround tube lets the electrodes used be a longer length, more like in the old Frankenstein movies, a lot of fun as a kid.
The one thing I can think of is that it blocks any external air currents form extinguishing the arc easily. Perhaps that's it?That's how I started. The tube does make a big difference. Something about the heat from the arc is contained and it can then jump a bigger gap, if I remember correctly. Or maybe it is the ionized air? Been many years since messing with one.
Yeah, guess what I was trying to say is that the top spread of the electrodes can be wider with a tube. With using the same input values. Almost double or more.The one thing I can think of is that it blocks any external air currents form extinguishing the arc easily. Perhaps that's it?
I always used higher voltage anyway (10-18kV) at 30-60mA so jumping the gap wasn't ever really a problem for me.
