I hate to say this, but it doesnt really look that big. You can still use it, but im not sure if you can pull 10 amps from it. Can you check the wire size of the secondary? That might tell us. You should probably test it at lower currents first and see if it overheats after several hours like overnight. A transformer that overheats melts the insulation and shorts out, blowing the fuse and then becomes useless except as a paper weight.
Also, if we measure the capacitance in ampere seconds per volt, at 50Hz the required capacitance is estimated to be C=0.01*I/V where V is the estimated desired ripple voltage. At 60Hz we could use a little less, 5/6 times that.
