sparky!(Sean)
Oh didn't see the last four posts, it didn't send me an email I think I will stick with the lm317, but I would like a 7 segment led voltmeter
For example, as the capacitor ESR goes down the diode peak current goes up, which means the power being delivered is being done over a shorter time, and with higher peak current the RMS current goes up even though the same amount of power is being delivered.
As somebody pointed out: a smart designer needs to recognize the difference between possible and feasible.This thread is getting very techy . . . but fundamentally it shows the difficulty of building a 10A PSU using a linear circuit.
i will have to take exception here. that is only true of a capacitor of infinite value. of for practical purposes, when the voltage ripple is held to a minimum value by the capacitor.
if the ripple voltage is allowed to be 1/2 the peak then the ESR has very little effect on the peak diode current.
Well im not sure why you would say that. The ESR come into play almost without regard for the capacitor value. To quote a few extreme values, with 10 ohms ESR that resistance could be almost equal to the load itself, which means the capacitor would see much less ripple current and after all the capacitor is what causes the peak current in the diode for the most part unless of course it is very small in value.
