Hi all, I'm having trouble with a simple 2 NPN transistor astable flasher circuit. It's a typical circuit seen everywhere and my outputs on each side are driving solid state relays that turn on a string of C7 lights each cycle. My timings are long, about 3sec on, 5sec off, and the circuit works fine. The problem is when I breadboard 3 or 4 circuits together all with different timings, they tend to start "synching up", flashing together, rather than maintaining their individual flash rates.
I've tried different RC values and still have the same problem. Does this sound like normal behaviour when running these circuits together? My bench supply is a very stable DC, so I don't think it's power related noise. I figure that when one circuit switches, it's also triggering another circuit that's close to its switch point. Is there a way to isolate them without using separate supplies for each circuit? I eventually would like to run the finished board with a simple (and cheap) 6-12V wall wart. Is there a better circuit to do what I need, i.e. 555? My projects will need from 3 to 6 of these flasher circuits on a single board eventually. If I need to provide any more details I will do so gladly!
Thanks for any insight into this. TP
