Neil Groves
I just layed out the syntom circuit on strip board, then wondered if i should breadboard it first, THEN it dawned on me about making the P.C.B for it, now my head is spinning with all the options of general construction techniques. Also should i buy the case first and then design the board to fit the case, especially if i use a case with pre formed slots for the board?
I intend at the moment to breadboard my experimental prototyping as it's easier to correct my screwups of which i am sure there will be plenty, then build it on strip board, i like strip board as if i mess up with component connections, it's easier to correct than having to cut P.C.B tracks and adding extra links.
I suppose it's safe to say that with circuits from magazines (although i am learning they arn't always error free) i could just go straight to strip board, just using the breadboard to actually get my own designs working?
Neil.![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
what do you people do as a general construction rule?
Neil.
