Thanks, I hadn't thought about that.
Hi What eric sugested is very good stuf for it If we have out door panels we use boxes from the same matterial different colors then transperant thought
take in mind that the heat transfer properties are not that good so if you talk about a heat generating amplifier make sure that you have the majority of the heat sink outsie of the eclosure and it always works to put some forced cooling in the enclosure
if forced cooling is used remeber that what goes in must come out
I ve see quite a few cases that they put the magic fan on the eclosure for blowing fresh air in the casing but no exit holes in it
the only thing the magic fan whas doing was wasting energy
Robert-Jan
Not quite. It pressurized the enclosure.
Yes you're right in that but if that is the goal you still have holes in the enclosure for heat removal and you install a bigger fan on it to keep a over pressure in the casing.
Robert-Jan
Holes have to be avoided under any circumstances.
